What I find interesting is the length of the robands that hold the sails to the yards. The tell-tail ends of the robands hang down onto the sails as long as the reefing points. Something to take note of in my build.On Vroom's pictures, topsails leechlines ommited as a rule, and only one central buntlines shown... later on, when martnets on the course sails disappeared at all, there are two leechlines only shown on the top sails and course as well ... as we could see on the Van de Velde drwngs...this is a difference , but in the same time, martnets for top sails halliards still in use...
Sorry to ask, what do you mean with martnets for top sail halliards?but in the same time, martnets for top sails halliards still in use...
When you zoom in you can see that these line hang in between the robands. When it where the long ends of the robands then they would hang on the back of the sail because the knot of the roband is on the back of the yard.What I find interesting is the length of the robands that hold the sails to the yards. The tell-tail ends of the robands hang down onto the sails as long as the reefing points. Something to take note of in my build.
Good day Stephan,Sorry to ask, what do you mean with martnets for top sail halliards?
The term Martnets is normally used for a leechline on a square rigged ship when it is arranged whit crowfeet. And only the course got them like your drawings show.
Or do you mean the crowfeet on the halyard of the topsail and topgallant yard?
Hello Kirill,Anybody knows , original Vasa blocks ... are they recovered , existed?
Where we could see them?
Have some Doubts that euphroe made by Paul have correct geometrical shape... but not sure...
Good morning Paul. Beautiful work as always. Those crows feet lines seem impossible to tension tight without pulling the stay up and thus not linear. I would be interested if any modeler has managed both. The chap on the knight head looks like he has been sent to the gallows-Hello Friends,
In order to get a head-start on the American holiday this coming Monday, I took today (Friday) off as well. With nothing planned I managed to spend most of the day working on my ship. It's been a while since I have been able to do that, so it was a special treat. Today's mission was halyards.
First up let's look at the halyard for the mizzen mast. Unlike the other halyards, which all run aft of their respective masts, the mizzen halyard runs forward. Here is the working end (yards are not yet installed so the line is just running through a sheave near the top of the mizzen mast and taped down for now):
On the fore topmast and the fore topgallant, the halyards run to the stays and end in crows-feet. This was extraordinarily challenging to accomplish because any tension on the halyard pulls the stay out of alignment - but the crows-feet need some tension, or they look sloppy. I made a builder's decision that keeping the stays relatively straight was visually more important than perfect crows-feet. I may change my mind later as the build progresses.
In the images below you can see how the working end passes through a directional block attached to the stay below the crows-feet and is then run to the base of the mast. Nearly everyone just ties the line off to an eyebolt. While I do not doubt this is correct, I can't see how that arrangement would allow for hoisting the yard. My solution was to add a block to the eyebolt so the halyard could be hauled on by a group of men on the deck, or even run to the capstan. I'm 90% sure I did this wrong...
Anyway, here is the foremast overall picture:
A closer look at the topgallant tie (tye) and halyard:
And now a look at the fore topmast halyard:
Here is how I have 'belayed' these halyards at the base of the foremast (one on each side):
Next, the overall view showing the main topmast and main topgallant halyards:
The main topmast halyard does not run to a stay, rather, it runs to a knighthead:
And finally, a closer look at the painfully difficult main topgallant crows-feet:
In the US (on Monday) we remember the men and women who died while serving in our military. I am grateful to them, as well as to all who have served. I hope you all have such a day in your home countries as well. It is a good thing to remember and give thanks, even as we long for a time when war will no longer be a part of our planet's story.
Thanks for visiting!
Just a few more random images someone might find helpful. Fore topgallant:
Fore topmast and part of the topgallant:
Fore topmast but closer in:
Fore topgallant again but closer...
Lovely work Paul,Hello Friends,
Exquisite work Paul. What a fine instructional photo essay which I will bookmark and use as a guide.Hello Friends,
Excellent idea Stephen!Lovely work Paul,
Maybe this is an idea for you and PeterG.
The crows-feet look like a hassle, I wonder if thinned PVA/white glue brushed onto the crows-feet whilst in tension would stiffen it up enough, maybe temporarily putting more tension on the stay to reduce the "kink" and once set reduce the tension in the crows-feet so the stay doesn't have a "kink" in it.
I would suggest doing some experimentation off the model with some sort of simulation.
Cheers,
Stephen.
