Today was my first foray into something that wasn’t structural…
There are two deck portions that sit below the main portions of the deck (I assume they will have grating or covers over them in places but will apparently be visible to some extent). Anyway, I got to do some decking.
To say I agonized over how to do this well is an understatement. According to Fred Hocker at the Vasa Museum the decking on the original is apparently random: random lengths set in a random pattern. And while that might be historically accurate when I did a mock-up I confess I didn’t like the look all that much. What to do? Am I beholden to historical accuracy or is there room for artistic license? The DeAg instructions call for a two-butt shift which is as far from random as I could imagine.
What I ended up doing was a five-butt shift. Why? It looked less like a pattern than other layouts but didn’t suffer from ‘randomness’ as a liability. I also kept the plank lengths the same – 60 mm which at a 1:65 scale would mean the full size boards would have been about 13 feet long. I thought this sounded reasonable but I’m an orthodontist not a shipbuilder so I might be completely off the reservation. Anyway, I felt this plank length produced a pleasing appearance. Not too busy and not too spartan.
I also agonized over the appearance of the decking. I tested out more stains, oils, techniques than I care to confess to. For example...
I think I spent less time choosing names for my children. I ended up selecting a simple summer oak stain and a matte poly finish. I’m pleased with the result, but I can’t help but wonder what you all think? The deck portions I have built thus far will be less visible than what is to come so if I need to change things I can and will. I could even overlay what I have completed to make it all look the same.
Thanks for checking in - and I am happy to hear your thoughts or suggestions!
I think it looks great! That's the same pattern I chose, since there was not any guidance on that feature.
Welcome to SOS, Paul!
I think you chose wisely with the D’Ag Vasa; it is, by far, the best of the available models.
You are off to a fantastic start, and I appreciate your ambition as a new builder. While I work in plastic, at present, I can offer you a bit of universal advice:
Above all else - consider your financial investment and then triple your investment in time to work through the construction carefully and methodically; eat that elephant one bite at a time, and you won’t choke on it.
I would also encourage you to do some of the ornamental paint work, concurrently, as you work on the structure, for two reasons:
First, there is so much ornament to do - and polychromatic, at that - that doing it all at once becomes a real chore. The temptation to rush through it can then become really hard to resist, but resist you absolutely should. In my opinion, two things often spoil what is otherwise a well-made model; glaringly wrong and/or out of scale details, and rushed sloppiness in fit and/or finish. Take your time, and you will never regret the extra effort.
The other major benefit of doing a little paint work at a time is that it gives you a break from the more tedious aspects of construction, like careful planking, for example. However, carefully painted ornaments are an enormous motivator to continue working on the build in a focused way, as you begin to imagine how vivid and spectacular the ship will look with your bright-work in place.
Now, a little specific advice.
As for fairing your hull, take a generous amount of time, and a reasonably stiff, yet flexible batten, to check all up and down your framing for highspots and hollows. Mark your highspots with cross-hatches, to roughly show what has to be removed, and use some similar annotation for areas that need to be firred-out with strip wood.
Then, do a pretty close fairing of your hull with the batten. Once you are really pretty close to fair, I suggest filling between stations, below the lower gun deck with blocks of balsa. At the very least, this should be done at the bow and stern. Doing so in-between, though, will provide greater surface area for glueing your first layer of planking. Also, if you do a very careful job of final fairing, you will ensure that your hull does not have any distracting bulges or hollows, after the finished planking is on and oiled, and the glancing light reveals everything. Again, take your time.
Lastly, I recently watched a builder make a fine model of this kit on MSW. He had been contracted to build the kit “exactly” as described in the instructions; although I can’t say from first-hand knowledge of the kit, this builder said that the instructions directed the builder to “plank” the stem and stern post as though they were continuations of the hull strakes. Despite his talent as a builder, and his proper knowledge of framing construction - he had paid orders and did as he was instructed.
The advice I will offer you is not to do this, as it is so completely wrong and distracting that it won’t matter how carefully you construct and finish the rest of the model. These big-timber framing elements have a very specific structure and joinery. Because the actual ship still exists, of course, it is an easy task to find out what her built-up stem would look like. With that knowledge, in hand, you can then veneer the stem/keel/sternpost to look like it is a built-up structure. Alternatively, you can scribe incised lines into a simplified three piece structure for the S/K/S. Or, you can go “whole hog” and build up what would be visible of the S/K/S. Any of those three options will be far superior to “planking” these elements.
I am loving this build, so far, and look forward to following along. Keep going - you’re doing a fantastic job!
Hello! Thank you for taking the time to share this thoughtful post.
I want to affirm your suggestion that I go ahead and begin working on ornamentation/painting. While I was going to just wait and do all that later I have already realized that the building process is more mentally taxing than I had anticipated (and slower!). Working on different aspects of the model seems like wise counsel. Thanks.
Interesting discussion on the DeAg planking instructions vis a vis the stem/keel/sternpost. This is an excellent example of why I need help from more experienced ship-builders. I tracked down some images from a book and understand what you have described. I'll do my best to represent this big timber accurately. I appreciate your expertise!
Before you start fairing the edges of the frames, paint them black. That way, you can see when your sanding approaches the edge of the curvature of the frame along one edge and stop before you take off too much wood and potentially create a flat spot on your hull. You can build up a mistake by gluing a piece of thin planking material onto the edge of a frame and re-sand it to shape, but you're better off just removing what you're suppose to and no more.
I used a small mouse sander to make fairing the frames go faster. The point can get in corners closer to the keel, where you finish the frame with a hand sanding block. It's a tough thing eyeballing the angles and checking them by bending a piece of planking over the frames ever minute of sanding. You're constantly afraid of taking off too much wood or making the angles incorrectly. You just have to go slow, trust your eyes, and check, check and check again to make sure it's going right.
I used CA glue or Titebond II Premium PVA glue. Like Uwek said, you're going to get 12 answers to that question! Any good yellow carpenter's glue is a must. When choosing thin fast setting, medium, or thicker slow setting and filling CA glue, choose medium since it's the most versatile. Get about 4 average bottles to start with. You'll use it. CA actually does pretty well for strength and I haven't seen any bonds break down in the last two years on the hull. When planking the first layer of planks, glue the planks edge-to-edge with PVA. You can us CA to make them stick quickly to frames in many places, but since you will be using a pin pusher tool and thin 7mm brass pins to hold the planks in place, PVA is a better choice even though it doesn't dry as fast. CA joints are brittle, and PVA joints are more flexible, so most of the planking except for those few springy planks in tight corners that WILL NOT STAY IN PLACE and drive you nuts are held with PVA.
Regarding the total expense for building a model ship, prepare to be shocked. See the spreadsheet below for the current cost of all materials, books, and tools used for building La Couronne up until today. The list below was updated on Jan 23, 2021.
Material Costs for Model of La Couronne c. 1636
Date purchasedQuantity & ItemsStorePrice
3/21/2018Corel La Couronne Wood Ship Model KitModel Expo
$383.99​
4/3/2018HULL PLANKING CLAMP SET OF 6 (LESS THAN 3/16 ), 2 6" Steel Ruler, Illuminated Dual Lens Flip-In Head Magnifier w/2 Lenses & Loupe (1.9x , 1.9x , 4.5x), DEADEYE/BLOCK THREADERS (PACK OF 4), Self-Healing Cutting Mat 18" x 24", Model Expo Nail Driver for Miniature Nails, COATED BRASS NAILS .028 X 1/2IN (.71X12MM) 200PCModel Expo
$81.94​
4/4/2018Ship Modeling from Stem to Stern by Milton Roth (book)eBay.com
$4.40​
4/15/2018POLENA FUSA LA COURONNE IN METALLO DORATO MODELLISMO NAVALE MANTUA 35600 (Mantua La Couronne figurehead in brass)eBay.com
$10.93​
4/22/201826 Cannon Barrel - Brown - Plain - 1-1/16" (27mm), 16 Cannon Kit - Metal - Brown - 19/32" (15mm), 16 Cannon Barrel - Brown - Plain - 45/64" (18mm)Modelers Central
$73.58​
4/22/2018RIGGING OF SHIPS: IN DAYS OF SPRITSAIL TOPMAST, 1600-1720 (DOVER By R. C. Anderson (book)eBay.com
$13.49​
4/24/201810pcs Metal Knitting Needles Crochet Hooks Kits With Ergonomic Grips 0.6-2.0mmeBay.com
$2.31​
5/2/2018LATINA 27024 Plank Bender LATR7550Amazon.com
$12.78​
5/2/2018Darice 24-Inch Stainless Steel RulerAmazon.com
$8.91​
5/2/2018Drill Warehouse 150Pcs Mini twist drill Bit Kit, 0.4mm-3.2mmAmazon.com
$14.99​
5/2/201890 Pc Multi-Grit Diamond Burr Set (600 Fine, 150 Medium, 40 Coarse)Amazon.com
$14.33​
5/3/2018Hand Archimedes DrillA.B. Tools Online
$13.70​
5/9/2018Fiskars Soft Grip 5" Easy Spring Action Scissors Micro-TipeBay.com
$13.06​
5/13/20184 Cannon Barrel - Brown - Plain - 45/64" (18mm), 2 Anchor - Curved - Old Style - 2" (50mm)Modelers Central
$31.32​
5/14/2018Maple Strip 0.5x2mm, 36465 Lifeboat Kit 72mm, 6041/01 Working Brass Single Hinges 6mm (Pack of 10), 4 4090/05 Chainplate with Deadeye 5mm (Pack of 10), 12 4307/00 Wooden Oar 35mm, C83505 Brass Etched Eyelet 0.3mm (250)Cornwall Model Boats Ltd
$61.39​
5/15/2018Modelcraft Pen Grip Pin Pusher, BrownAmazon.com
$14.49​
5/15/2018Black 100 Pack Of Pins For Ppu8174 Pin Pusher (2)Amazon.com
$14.56​
5/20/20181Set Mini Hobby DIY Razor Saw Kit Handy Craft BladeeBay.com
$11.04​
5/20/2018Plank on Frame Boat Kit by Model Shipways, 3-3/16" longEva Mosko (eBay)
$8.99​
5/20/2018Hobby Model Ship Tool Ropewalk for Scale Rope MakingeBay.com
$40.00​
6/14/2018Art Alternatives Box Compass Complete SetAmazon.com
$10.09​
6/14/2018Warships of the Anglo-Dutch Wars 1652–74 (New Vanguard)Amazon.com
$12.44​
6/14/2018Squadron Products Value Pack Sanding Sticks (2)Amazon.com
$9.99​
6/14/2018Craft Sanding Scraps, 5 Oz Bag, Mixed Grit, Various Shapes & SizesAmazon.com
$6.99​
6/22/20181 Oz. Bulwarks Gun Carriage Red - Model Expo Paint - Historic marine colors, ELECTRIC PLANK BENDER, 1 Oz. Black - Model Expo Paint - Historic marine colors, SN-LT24 ILLUMINATED DEADEYE/BLOCK THREADERModel Expo
$38.96​
6/23/2018Birchwood Casey Brass Black Metal Finish, 3-OunceAmazon.com
$8.77​
8/12/201830351 Cast Lantern Set La CouronneCornwall Model Boats Ltd
$28.46​
8/12/2018LED's, A/C Power SupplyEvan Designs, Inc.
$66.80​
8/15/20184 Cannon Barrels - Brown - Plain - 1-1/16" (27mm), Rigging Wax - Clear, Rigging Wax - Black,Modelers Central
$29.66​
8/22/20181/96 Early 19th Century Sailor FiguresAmazon.com
$24.76​
9/11/2018Striveday™ 30 AWG Flexible Silicone Wire Electric wire 30 gauge Coper Hook Up WireAmazon.com
$21.98​
9/9/20182 Packs Nails, Brass .028 X 5/16 (.7x8mm) 1500 per ackModel Expo
$35.97​
9/19/2018Masting and Rigging of English Ships of War by Lees hc 1984 Model Making Sails (book)eBay.com
$42.00​
9/28/2018Model Expo Nail Driver for Miniature
Nails, Pinstripe Tape 120 3/32" - Red, Planking the Built-Up Ship Model (Book)
Model Expo
$43.96​
10/10/20186 Piece Ship Curve Set [Alvin]Drafting Supplies Dew
$23.05​
10/10/2018Naval Warfare in the Age of Sail - War at Sea 1756-1815 by Ireland, B. (book)eBay.com
$5.50​
10/10/2018Construction and Fitting of the English Man of War 1650-1850 P. Goodwin (book)eBay.com
$30.00​
10/10/2018The Arming and Fitting of English Ships of War 1600-1815 by Brian Lavery (book)eBay.com
$30.00​
10/16/2018Sovereigns of the Sea: The Quest to Build the Perfect Renaissance Battleship (book)eBay.com
$3.50​
10/25/2018Dremel 575 Right Angle Attachment for Rotary ToolAmazon.com
$21.23​
10/25/2018Dremel 4300 kitAmazon.com
$89.00​
12/6/2018Artesania Latina, S.A. 27300 Micro Shapers No.1Amazon.com
$13.92​
12/14/2018Sapele Wood wood strips 0.5x5x500mm for Wooden ship Kit - Pack of 20eBay.com
$21.00​
12/22/20185 Falkonet - F20B1 - Single Block 2mm Pear Wood - Pack of 10, 5 Falkonet - F20B2 - Double Block 2mm Pear Wood - Pack of 10Model Expo
$38.89​
12/27/2018Blocks & FittingsScale Model Supplies
$35.05​
12/27/2018Dremel Polishing BitsHub Hobby
$11.80​
12/28/20189V 2A AC/DC Power Adapter 18W Charger for IEIK UNO R3, Arduino UNOAmazon.com
$19.26​
12/28/2018UNO Project Basic Starter Kit with Tutorial and UNO R3 for ArduinoAmazon.com
$18.20​
12/28/201850pcs Solder Seal Wire Connector, Sopoby Solder Seal Heat Shrink Butt ConnectorsAmazon.com
$12.44​
12/30/20188 Falkonet - F20B1 - Single Block 2mm Pear Wood - Pack of 10, 8 Falkonet - F20B2 - Double Block 2mm Pear Wood - Pack of 10Model Expo
$56.83​
1/1/2019Gold CrownsEtsy
$5.48​
1/2/2019Brass Etched Eyelet 0.3mm (250)Maritime Models
$29.57​
1/16/2019Wood Strip CutterMicro-Mark
$20.90​
1/25/20194 C31 Cannon Barrels with Carriage Bronzed 25mm, 24 4030/18 Turned Columns Boxwood 18mm, Sovereign of the Seas Plan Set, C86120 Wooden Column 28mm (Pack of 5)Cornwall Model Boats Ltd
$55.34​
1/25/2019Fiskars Easy Action Micro, Tip Scissors, 6" (190500)eBay.com
$4.95​
2/1/201935690 Pair of Doors (Stern Windows)Cornwall Model Boats Ltd
$16.42​
2/1/2019Flag Set - La Couronne, Deco - Stern - French Coat of Arms 48x32mm, 2 Door/Window Frames - 28x12mmModelers Central
$36.71​
2/6/2019Deco - Wreath - 10mm, Nails - Black - 9/32" (7mm) - P150Modelers Central
$8.78​
2/18/2019Plano 2360001 Prolatch StowAway 3600 Locking Fishing/Tackle Utility BoxeBay.com
$17.86​
3/12/2019Mantua Model 37360 Brass Gun Port Hinges - 0.3 x 2 x 10 MM - Pack of 10 pcs., INSTA CURE+™ SUPER GLUE CA 2 oz. (Gap Filling), NO.17 SMALL CHISEL EDGE BLADE 3/8 (PKG 5), EXCEL NO.11 SUPER SHARP BLADE (PKG 5), BLOCK BUSTER - HIGH SPEED BLOCK SHAPERModel Expo
$34.95​
3/14/20195 C86050 Grating Sets 33x33mmCornwall Model Boats Ltd
$17.56​
3/21/20198 Falkonet - F90WN - Wood (Pear Wood) Belaying Pins - 9 mm -10 pack, 8 Falkonet - F20B1 - Single Block 2mm Pear Wood - Pack of 10, 8 Falkonet - F20B2 - Double Block 2mm Pear Wood - Pack of 10Model Expo
$79.81​
3/23/20196" Brass Leaves Decorative BandingFundametals Annex (Etsy)
$8.52​
3/23/201961cmx1mm/1.4mm Brass Bead WireQFMarket (Etsy)
$12.75​
3/27/2019SotS Cannon Barrels Various Sizes, 50 6mm La Couronne Rail ColumnsCornwall Model Boats Ltd
$61.95​
4/9/2019Set of Needle FilesHome Depot (Husky)
$10.69​
4/23/2019Corel decoration D300, pack of 6, x3Cornwall Model Boats Ltd
$11.81​
5/11/2019Cyanoacrylate Glue, Pin Vise, Chisel Razor BladesHub Hobby
$28.00​
6/6/2019PEC Tools 12" 300 mm English / Metric black chrome, "high contrast" machinist ruler with markings .5mm, mm 1/32" and 1/64"Amazon.com
$21.39​
6/23/2019Caldercraft CatheadsMaritime Models
$8.38​
6/28/2019Two Amati 50mm Anchors, three Mast FeetCornwall Model Boats Ltd
$11.16​
6/30/2019Glue Bottle, Maple & Basswood Strips,Hub Hobby
$1.54​
7/4/2019Gold CrownsEtsy
$11.80​
8/21/201910 Falkonet - F80WN - Wood (Pear Wood) Belaying Pins - 8 mm -10 pack, 10 Falkonet - F20B1 - Single Block 2mm Pear Wood - Pack of 10, 10 Falkonet - F20B2 - Double Block 2mm Pear Wood - Pack of 10Model Expo
$76.99​
9/21/2019Rigging Line, 0.88mm, 1.14mm, 0.20mm, & 0.45mm, Dark BrownSyren Ship Model Co.
$27.50​
10/7/2019Riggin line, 0.3mm, 0.5mm & 0.7mm rope (3 strand) and 1.0mm & 1.5mm Cable (4 strand)Domanoff's Workshop
$85.00​
10/27/2019GALLEON: Great Ships of the Armada Era by Kirsch, P. (book)eBay.com
$32.13​
11/28/20191 x Spiral Mini-Drill, 2-Pc. 6" Steel Ruler Set 6" x 1/2", F90WN Falkonet - F90WN - Wood (Pear Wood) Belaying Pins - 9 mm - 10 packModel Expo
$37.93​
12/27/20192 x GS Jeweler's Hypo Cement, 1/3 oz.Amazon.com
$9.00​
1/1/20204mm Stropped blocks (6), 0.008"x30" manila rigging line, bucketScale Model Supplies
$10.00​
1/1/2020Sail ClothScale Model Supplies
$7.00​
1/25/2020Thermally bonded 0.06" Black ThreadHobby Lobby
$10.59​
2/7/202010mm Hearts, 40mm Chainplates, 7mm DeadeyesModel Expo
$39.97​
2/8/20209" Band SawHarbor Freight
$119.00​
2/9/20204 Violin Blocks - C8107VBW, 114 7mm & 162 5mm Triangular Deadeyes - A4060/07, A4060/05Cornwall Model Boats Ltd
$46.64​
2/11/202022 Gauge Stainless Steel WireStuff Crafts (Amazon.com_
$4.33​
2/28/2020Paper 3mm Triangular Deadeyes - V-ABS027Cornwall Model Boats Ltd
$17.21​
3/15/2020L61 Chainplate assembly for 7mm Deadeye (30), 6 x C8107VBW Violin Block Walnut 7mm (Pack of 2), 2 x 37291 Heart Block Walnut 7mm (2), Paper Heart Blocks 6mm (Pack of 8)Cornwall Model Boats Ltd
$25.50​
3/25/20200.010" 0.24mm Sheet Brass, 0.79mm 20g Blackened Copper Wire, 2 x Small Pliers, 0.23mm Brown ThreadHobby Lobby
$43.57​
4/4/2020Brass wire, 26-24-22-20-18-26 GaCopper Wire USA (Amazon)
$14.73​
5/6/20203 x Falkonet Blocks 3.5mm (pack of 10) F35B1, 4 x Falkonet Blocks 4mm (pack of 10) F40B1, 5 x Falkonet Blocks 5mm (pack of 10) F50B1Modelers Central
$57.87​
5/16/20203 x Falkonet Blocks 3.5mm (pack of 10)Model Expo
$11.97​
5/22/20201/4"x1/4"x24" and 1/8"x5/16"x24" WalnutHub Hobby
$1.04​
6/22/20203 x Falkonet F90WM, Wood Pear Belaying Pins, 9mm, 10 packModel Expo
$17.49​
7/28/20201.1 Yds Shao Stretch White Sateen, Fabric Stiffener Spray, Two Spools Thread (colors 8540 Mushroom, 8060 Hemp)JoAnn Fabrics
7/28/2020Coleman 32 Oz. KeroseneAmazon.com
$14.25​
7/29/202016 Oz Pine TarPremiere 1 Supplies
$21.98​
7/29/2020Ivory Sateen fabric, 3% spandex 97% cottonEtsy
$13.97​
7/29/2020Coleman 32 Oz. KeroseneAmazon.com
$14.25​
7/30/2020Seventeenth-Century Rigging: A Handbook for Model-Makers, Roger Charles AndersonAmazon.com
$7.80​
7/31/2020Rigging Line: 2 x 20' 0.20mm Light Brown, 2 x 20' 0.45mm Dark Brown, 2 x 20' 0.63mm Dark Brown,Syren Ship Model Co.
$41.30​
8/14/2020Beading Needles, Two Spools Poly Thread (colors 8540 Mushroom, 8340 Sahara)JoAnn Fabrics
$14.38​
8/17/2020Two Spools Poly Thread (color 8030 Ecru)JoAnn Fabrics
$7.98​
9/15/20202 x Heavy Black Button Thread, 2 x Heavy Khaki Button Thread, Brown Heavy Duty ThreadMichaels
$10.58​
10/8/2020Saint Louis Flags (AM5700/16), Sovereign of the Seas Nameplate (AM5621/02S), Plastic Mounting Dolphins (4/pk, AM5686)Ages of Sail
$44.07​
11/1/2020Hemastat, curved nose, and Archimedes DrillHub Hobby
$24.92​
Total
$3067.96
Since all my frames were laser cut they were burnt brown on the edges already. As a result I did exactly as you described...I used the dark edge as a guide to know when I was in danger of going too far. That worked really well and as far as I know I did not over-shape. I wish I had thought of a powered sander. Then again, that's probably a better tool in your hands than in my novice ones. The sanding blocks I used were probably a safer (albeit slower) route.
It may be slower, but there is less chance of over sanding, and you take longer doing visual inspection to make sure you didn't miss any spots. Looking awesome so far. I have to finish La Couronne so I can start HMS Sovereign of the Seas and catch up with you! :)
$383.99​
$81.94​
$4.40​
$10.93​
$73.58​
$13.49​
$2.31​
$12.78​
$8.91​
$14.99​
$14.33​
$13.70​
$13.06​
$31.32​
$61.39​
$14.49​
$14.56​
$11.04​
$8.99​
$40.00​
$10.09​
$12.44​
$9.99​
$6.99​
$38.96​
$8.77​
$28.46​
$66.80​
$29.66​
$24.76​
$21.98​
$35.97​
$42.00​
Model Expo
$43.96​
$23.05​
$5.50​
$30.00​
$30.00​
$3.50​
$21.23​
$89.00​
$13.92​
$21.00​
$38.89​
$35.05​
$11.80​
$19.26​
$18.20​
$12.44​
$56.83​
$5.48​
$29.57​
$20.90​
$55.34​
$4.95​
$16.42​
$36.71​
$8.78​
$17.86​
$34.95​
$17.56​
$79.81​
$8.52​
$12.75​
$61.95​
$10.69​
$11.81​
$28.00​
$21.39​
$8.38​
$11.16​
$1.54​
$11.80​
$76.99​
$27.50​
$85.00​
$32.13​
$37.93​
$9.00​
$10.00​
$7.00​
$10.59​
$39.97​
$119.00​
$46.64​
$4.33​
$17.21​
$25.50​
$43.57​
$14.73​
$57.87​
$11.97​
$1.04​
$17.49​
$14.25​
$21.98​
$13.97​
$14.25​
$7.80​
$41.30​
$14.38​
$7.98​
Total
$2,988.39
LOL Redface. Is the kerosene in case something goes irreparably wrong?
$383.99​
$81.94​
$4.40​
$10.93​
$73.58​
$13.49​
$2.31​
$12.78​
$8.91​
$14.99​
$14.33​
$13.70​
$13.06​
$31.32​
$61.39​
$14.49​
$14.56​
$11.04​
$8.99​
$40.00​
$10.09​
$12.44​
$9.99​
$6.99​
$38.96​
$8.77​
$28.46​
$66.80​
$29.66​
$24.76​
$21.98​
$35.97​
$42.00​
Model Expo
$43.96​
$23.05​
$5.50​
$30.00​
$30.00​
$3.50​
$21.23​
$89.00​
$13.92​
$21.00​
$38.89​
$35.05​
$11.80​
$19.26​
$18.20​
$12.44​
$56.83​
$5.48​
$29.57​
$20.90​
$55.34​
$4.95​
$16.42​
$36.71​
$8.78​
$17.86​
$34.95​
$17.56​
$79.81​
$8.52​
$12.75​
$61.95​
$10.69​
$11.81​
$28.00​
$21.39​
$8.38​
$11.16​
$1.54​
$11.80​
$76.99​
$27.50​
$85.00​
$32.13​
$37.93​
$9.00​
$10.00​
$7.00​
$10.59​
$39.97​
$119.00​
$46.64​
$4.33​
$17.21​
$25.50​
$43.57​
$14.73​
$57.87​
$11.97​
$1.04​
$17.49​
$14.25​
$21.98​
$13.97​
$14.25​
$7.80​
$41.30​
$14.38​
$7.98​
Total
$2,988.39
This is an amazing list, but from my point of view, does not reflects the cost of building "a model ship" as many elements/tools of your list will be used for years to come.... and for many kits.
Besides, buying so many model ship aftermarker parts is a "modeler decision" that depends on many things, like to what level of quality and historical/scale accuracy you want to take your model ship kit, what kind of woods "you would like to use" instead of the provided ones... etc..... "modelers decisions"
Cheers
Daniel
$383.99​
$81.94​
$4.40​
$10.93​
$73.58​
$13.49​
$2.31​
$12.78​
$8.91​
$14.99​
$14.33​
$13.70​
$13.06​
$31.32​
$61.39​
$14.49​
$14.56​
$11.04​
$8.99​
$40.00​
$10.09​
$12.44​
$9.99​
$6.99​
$38.96​
$8.77​
$28.46​
$66.80​
$29.66​
$24.76​
$21.98​
$35.97​
$42.00​
Model Expo
$43.96​
$23.05​
$5.50​
$30.00​
$30.00​
$3.50​
$21.23​
$89.00​
$13.92​
$21.00​
$38.89​
$35.05​
$11.80​
$19.26​
$18.20​
$12.44​
$56.83​
$5.48​
$29.57​
$20.90​
$55.34​
$4.95​
$16.42​
$36.71​
$8.78​
$17.86​
$34.95​
$17.56​
$79.81​
$8.52​
$12.75​
$61.95​
$10.69​
$11.81​
$28.00​
$21.39​
$8.38​
$11.16​
$1.54​
$11.80​
$76.99​
$27.50​
$85.00​
$32.13​
$37.93​
$9.00​
$10.00​
$7.00​
$10.59​
$39.97​
$119.00​
$46.64​
$4.33​
$17.21​
$25.50​
$43.57​
$14.73​
$57.87​
$11.97​
$1.04​
$17.49​
$14.25​
$21.98​
$13.97​
$14.25​
$7.80​
$41.30​
$14.38​
$7.98​
Total
$2,988.39
all the equipment is gonna be used on other ships and other hobbies, you can now do croche needle work
