THANK YOU DON VERY MUCH ONE OTHER QUESTION, DO YOU FIND THE WELL BOND SETTING UP TO QUICKLY I HAVE HAD THIS PROLEM WITH WELL BOND ON THE FRAMES, THANKS. GOD BLESS STAY SAFE YOU AND YOURS DON
Hello Don, Yes I can see that, I can hardly wait to be able to start my YQ Bluenose.Thanks Lawrence, for the most part it has been fun so far
Considered myself lucky as I will have drinks (coffee ), and donuts! Yay!!!This makes me happy, in fact I'm so happy that if any of you are in the neighbourhood stop in and I'll pour the drinks. In Jimsky's case coffee and donuts!!!
Great job Don! Nice recovery on the scratch built side.Method two of filler block construction:
Now for those of you who tend to over sand, drop and break and generally screw things up here is how to fix things. Go through your scrap frame billets, I hope you saved them if not skip this process and go to liquor cabinet! Using table saw cut strips to width then to length and laminate together. Next is to cut the groove on the inside, this is done free hand so please no partying before attempting this!
Top line is showing the final size I want and the bottom line shows where the curve or taper is going to start
shaping has begun using belt sander
Final shaping done, new block on the left and the old on the right. Final sanding and shaping will be done inside.
I have pictures of final product installed on ship but I seem to have lost them. I'll go look for them and be back, good chance I left them by the vodka bottle.![]()
