ZHL Black Pearl 2020 Golden Edition [COMPLETED BUILD]
I tried a few different spacing for the ratlines this one looked about right and was the same for all the masts.
This is the link for the sails check his other pages they're excellent.
Also check @moreplovac Brigantine Phoenix log post 374 there is some very detailed information on sail making, as always I only found this after I had made my trail sails.
Looks like a lot of work. I'm glad my wife can sew!
G;day Tony H Terence here Great job on the sails I to had a bit of a job on rat lines found how to on Utube then after a bit of a practice managed to get them done see attached photos now its all go. Thanks again for all the information on masts just started working on them regards Terence (terry)
Hi Terry it's coming on nicely you'll be over taking my build soon.
Finally finished the ratlines here is a few photos
IMG_20210816_153420.jpgIMG_20210816_153431.jpgIMG_20210816_153206~2.jpgIMG_20210816_153408~2.jpg
I had a bit of trouble with some knots coming loose I think this is due to the supplied rope being quite soft. After a while I didn't mind doing this job which was a surprise to me.
Question the instructions show no ratlines on the top masts, these will be difficult to tie as the shrouds are thin.
Should there be ratlines on these?
Tony, they might not have been there. They simply lowered the rey to the level of Mars and assembled the sail.
View attachment 251401View attachment 251400View attachment 251399View attachment 251398
There were none on my model either.
I think it was typical not to have ratlines in the upper parts of the masts.
Now the ratlines are done I can finish off the masts and standing rigging.
I used two tooth picks to hold the mast in position while the glue set.
The standing rigging was pretty straightforward.
IMG_20210820_163939.jpgIMG_20210820_164207.jpgIMG_20210820_164117.jpgIMG_20210820_164300~2.jpgIMG_20210820_164222~2.jpg
All finished, a few of the lines are held on temporarily incase I need the access later.
Next job, put the blocks on the yards and make some sails.
View attachment 252589View attachment 252590View attachment 252591View attachment 252592View attachment 252594
Wow...impressive work Tony...loved the shrouds and ratlines, especially the way you seized the shrouds around the mast. Small details but really add to the overall look of the ship.
Hi Tony. I have no idea underneath what rock I was sleeping to have missed your great-looking BP. She is a stunner - very well executed and is a model that you can be proud of! Thumbs-Up
Thanks for all likes and complements it's very encouraging.
I'm making progress with the sails, I wasn't happy with the material provided in the kit so I looked at making my own. Browsing online I found a way to make them with no sewing required, the link is on post #274.
I've simplified and adapted the method to suit.
Firstly I checked the size of the sails by making paper templates the drawing sizes are not very good.
I got some cotton material to experiment with. The colour was achieved with a acrylic wash then coated with a 50:50 PVA water mix to stop the material fraying when it's cut.
The material was cut into 20mm strips.
The strips are stuck together with a 50:50 PVA mix applied with a syringe, the overlap is 1.5 - 2mm.
The sail is cut out then the edges added.
After final trimming next job is adding the rope around the outside.
Very nice. I agree with your comment on the sail material that is supplied. I think I will try to do something similar to what you are doing. Thanks for the ideas and link provided earlier. I am thinking of a more grey color for the sails since it is the Black Pearl.
