ZHL Black Pearl 2020 Golden Edition [COMPLETED BUILD]
I’m going to fab some parts and do
all the painting but I’m not going to install them until the end.... I know I will break them if I don’t.
The whole time I was reading your post I kept thinking - I hope he doesn't break them later. And then you wrote the same thing! Is there any way to protect them? Pack out the area with something? Build a little cover?
The only way I'm not going to brake them is put some mast stumps in and make it an Admiralty style ship but where's the fun in that? LOL
Just about finished the hull today so time for a few photos. I achieved something I don't do very often, see if you can spot it in the photos.
So what was my achievement? In order to take the photos I had to have a tidy up and put all my stuff away, first time since I started my BP. Next week will be spent looking for the tools I put away.
I noticed your clean workspace right away. I'm wondering what it is like to have one? Great job! Are you planning on going admiralty after all? My Admiral wanted the sails.
Amazing, I hope mine turns out half as good. I love the walnut finish, way better than all black.
Larry
G'day installing the LEDs gave me a few headaches first I was not sure if I would fit them but it would be a good learning experience as I have never used them before. I ordered100 5mm yellow flickering LEDs from eBay but with the lock down delivery took over 3 weeks which slowed down the build.
I made a test rig to run 17 LEDs on a USB, I chose USB because there's always a power supply or power pack around I'll have no trouble lighting this BP up. The wire from a Cat5 cable was used for the LEDs
I soon realised I should have planned out the LED locations and wiring before glueing the bulkheads that way drilling the holes for the wires would be easy I also had to cut away some of the wood under the grates.
View attachment 205493View attachment 205495
I made a box to go under the grates with the LED on one side and reflective material to bounce the light up on the other side.
For the lamps I drilled 3 2.5mm holes in part 17 if I hadn't glued it on slots may have been better, I also used the wire that came with the kit for these.
6 LEDs have been used for the cabin, as it not fitted to the ship and there is a lot more work to do on it the LEDs can be easily removed.
As I didn't want wires coming out of the hull I made two copper contacts on the bottom of the keel to power the LEDs.
Ready for the next part
TonyH:
This is a very impressive build with lots of lights that makes it look alive.
I have a question fir you: Where did you purchase your long drill bits from?
Keep up the excellent work.
I'm tempted but the main reason I started this kit was because I had not built a model for 25 years I wasn't sure how I'd go. As this is a learning experience for me I want to go all the way. Rigging is the part that will be the hardest part for me and the instructions are poor. I'll take my time and read some of the books that I keep buying and not looking at.
Will
you do buntlines and clew lines? I passed on them.
TonyH:
Thanks for the encouraging comments as I'm heading into uncharted waters ( rigging ) without a good map (instructions) but if I get into trouble I'll use the stars (forum members) to find my way.
I ordered most of my drills through work but most engineering supplier's should stock them, I also found them on EBay just look for long series drills. I have long series drills from 1/16 up they are very handy for getting into tight spots just rember to take the drill out of the hole to keep the flutes clear.
Tony
