- Jan 21, 2022
I salute your persistence and patience!Update on port lids
Almost all of first part of port lids are ready to glue and paint. There's a matter how to finish them
I did one attempt how it would look and how much dose it take to make one. The difference is too significant to ignore it. I was thinking how to do it so as not to get stuck doing only this thing and I came to the conclusion that I'd rather do 1 piece, even per week at a time, than go with simplification. In addition, they will be mounted at the very end so that they don't get damaged, so there is a lot of time. It remains only to complete the hull with pipes for ropes and I can proceed to the next stage.
Next stage:
I did some attempts how to make this pins marked in green
There is no great philosophy here, you just have to hit it with a hammer The matter is made easier by the fact that I found a Tamiya puncher with a diameter of 1.5 mm, otherwise it would not be so rosy Sooo you need to hit it with a hammer about 480+ times then drill with a 0.5mm drill bit in a 0.2mm copper plate and here you go
Time consuming but rewarding decision. Go for the details to the level you are able to make them.Thanks Paul
I have 64 port lids to make if I could do 1 per week that leaves me with 16 weeks. That's not some unimaginable time period. Completion of whole model will take much more. I think you know how much it takes to fully rigg a ship of the line
Cześć MirekWitaj
Cierpliwość popłaca bądź wytrwały. Pozdrawiam i czymam za ciebie kciuki Mirek
No problemI salute your persistence and patience!
I would be happy to learn from you how you produce the effect of the nails that are mounted on the inside (painted red) of the cannon port cover. Thank you
Thank you . Job is pretty easy, difficulty comes in amount of pieces to makeVery fine detail work.
Thanks. I'm afraid after finishing that I'll start thinking about copper platingGreat work so far.
Nie. Z tym i tak będzie aż nadto robotyWitaj
Wojtas czy będziesz kołkował poniżej wali. Pozdrawiam Mirek
Good morning. Wow- that is a load of nailing. It looks awesome though. Cheers GrantHere are the effects of few hours of work over the past week. The work is quite easy but time consuming.
It's a small portion, but you can already see the difference. In "+" or in "-"? I don't know. Now I must finish it no matter the result.
