- Apr 8, 2023
5/5/23 to 5/5
Got this kit about a month ago and have been waiting to start it until I got to Vallarta, and I’m finally here. Since it is only my second build and my first not at home, I knew just getting everything to Mexico would be a bit of a challenge. After all, I’m still learning what tools and supplies I need at home, let alone trying to pack them up for Mexico. I was taking the approach of bringing whatever I thought I’d need and leaving it here. Adding to the challenge is flying not just internationally, but on Frontier.
Normally we fly here on Southwest, but this time we tried Frontier, and a 40 pound checked bag limit (Southwest is 50 pounds). You might think 40 pounds is plenty, but that one checked bag is for both my wife and myself. Luckily as we got close to the limit, my wife suggested pulling a few things out, and none of them were model making stuff. She’s definitely a keeper.
I know I said on my Bluenose build to not set tough goals on what to accomplish on the build, but that doesn’t mean to not set goals. I’m hoping to get the keel and bulkheads together, including some temporary battens attached to the bulkheads to reduce any warping or twisting that may occur in the hot and humid climate (completely opposite of what I’m used to in Denver, CO) and maybe the decking. I have about two and a half weeks here before heading home with our next trip down here in probably late October. It really isn’t too much work, so it should be doable.
I expect at a minimum to have a couple of hours each morning (wrapped around my morning walk on the malecón/beach) as I wake up early and my wife sleeps in.
The view from my work place is definitely different than at home. Instead of looking out at my pine tree lined yard, it a tropical vibe overlooking the pool and courtyard.
Now it’s time to settle in and make sure everything is in the box. Everything appears to be here. I was fearful of some of the metal pieces missing but they were layered in with the laser cut wood.
Today I labeled all of the pieces on the laser cut wood, and cut out all the keel and bulkhead pieces.
Next up, sanding and dry fitting the bulkheads.
Time for this portion: 1.5 hours
Total time to date: 1.5 hours
