Good morning Michael. Wonderful execution of a tricky task. Cheers GrantView attachment 439046View attachment 439047View attachment 439048Starboard fore channel deadeyes and chains and bolts installed.
Grant thank you for your compliment and interest, it is truly appreciated.Good morning Michael. Wonderful execution of a tricky task. Cheers Grant
Good morning.Small and tricky these little boats may be, however you are owing them! Cheers GrantMaking progress with the ship boats and building the mast tops.
The boats are challenging projects as the smaller size accentuates any imperfections.
View attachment 442772View attachment 442773View attachment 442776View attachment 442778View attachment 442779View attachment 442780
Creating the rounded edges of the 3x3 bolsters on the tops required me to use my MF70 with a router bit. I am happy with the result but couldn’t think of any other way to achieve the same result by hand. I would be interested to know if anyone has any suggestions or experience to do the same.
View attachment 442771View attachment 442774View attachment 442775
Thanks Grant. They will be filled with equipment, oars, rope, grapple anchor and pikes.Good morning.Small and tricky these little boats may be, however you are owing them! Cheers Grant
Thanks Allan. Your comments are always well considered and well received. I will read up on these references.Your boats look quite nice. For the future keep in mind barges and pinnaces were typically single banked. Even a 36 foot barge was single banked and had ten thwarts with one rower per thwart so the tholes alternated on each side. Cutter were single banked most, if not all of the time and were lap straked (clinker built) rather than carvel built. I realize these are probably kit boats/instructions, but for any build it is often a good idea to look at drawings and information based on contemporary sources to confirm or correct what may be in the kit. There are a LOT of details on ships boats in Brian Lavery's The Arming and Fitting of English Ships of War and in W.E. May's The Boats of Men of War. Actually, making boats from scratch is not difficult and the results are usually superior.
That it most certainly is. Cheers GrantNice clean work my friend!
