- Dec 1, 2016
another method used by Harold Hahn was form bending.
he would make a jig using the hull lines for the shape of the hull. Then use thin pieces of wood soak them and press them into the forum. He did several laminations when each was dry he used glue and put the pieces in the jig and clamped it closed until the glue dries. Once the glue dried it held the shape which would lay perfectly against the hull. sometimes he used all the same wood and sometimes he used different types of wood
