Stephan, I am wondering if they ever respond to your querry?I send an e-mail with the question if they deliver to the USA below 2 kg. We wait.
Good that you ask. Short answer, no they didn't. Strange.Stephan, I am wondering if they ever respond to your querry?
Yes, Thank you, Steph. I get an email from Petra, a few minutes back. I already called stepcraft, they no longer partnered and selling Proxxon and their parts. I asked Tobi @Tobias for help, and he gladly suggested he will purchase it for me and ship it to the USA.@Jimsky I got mail. Hope you got something about this answer.
Sehr geehrter Herr S. kertesz,
vielen Dank für Ihr Interesse an unseren Produkten.
Wir liefern nicht nach Amerika. Wir kooperieren jedoch mit Stepcraft US, Torrington, CT 06790
https://www.stepcraft.us/
Vieleicht können Sie dort das Produkt, dass Sie benötigen finden.
Mit freundlichen Grüßen
Petra Buttgereit
USOVO
Inh. Peter Urban
An der Beile 2
D-58708 Menden
Telefon 0049 (0) 2373 17911 65 Mail: mail@usovo.de
Besuchen Sie uns auf www.usovo.de
Visit us on www.usovo.de
English:
Dear Mr S. kertesz,
thank you for your interest in our products.
We do not deliver to America. However, we cooperate with Stepcraft US, Torrington, CT 06790
Maybe you can find the product you need there.
With kind regards
Petra Buttgereit
But when you take a closer look, they have mention the US in their postage costs-table
Yes, Mon Amie. I saw this video highly recommend it as a must upgrade to all Proxxon MF70 users. It is worth saying, IMHO, that the most challenging task, while using MF70, requires some force and effort, is to use the vertical feed screw. This video is a great help as @Steef66 Stephan mentioned and can be accomplished without difficulties, but the improvement is worth trying.Did you see this video?
He added a set of bearings to the z-axis. You can see this at about 2 minutes into the video. I ordered this bearings and ad them to the z-axis. Turning the adjustment wheel of the z-axis is very heavy and your cutter moves back and forth when you do this. But after adding these bearings, it goes very smoothly. I can turn the wheel with one finger.
Add a bearing above and below the plastic cap that is fastened with 4 socket-head screws (2 bearings in total) and put the whole back. It takes some effort to loosen and tighten the locknut. And the existing brass ring that sits between the locknut and the cap is no longer needed.
Be sure to add bearing grease to the shaft and bearings when reassembling.
I ordered these bearings on Ali-express. F6-12M You get 10 of them, so you can also provide the x,y-table with bearings. But in the video, he explains that this does not add much to an improving effect. So I did not do this.
Highly recommended for upgrading your MF-70.
Here are the bearings I bought for this task and the link to AliExpress. * The red square is the part you will have to order.
3.84US $ 10% OFF|5pcs F2 F2.5 F3 F4 F5 F6 F7 F8 F9 F10 F12 Miniature Bearing Plane Thrust Ball Bearing - Bearings - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Thanks, Daniel. Installing the thrust bearing could be done without a professional, but yea...professional will do it with confidence for sure.Thank you Jimsky for the details and links. I ordered the F6-12M as you pointed. I will ask my friend to install them. Opening the MF70 scares me , also if is just a few screws.
Cheers
Daniel
Are you able to spec the quill without the adapter? Is there a guaranteed accuracy? Or is it fully acceptable? You know, for a price, a machine shop might make a replacement. But if the quill is causing the wobble, maybe replace the bearings?Greetings folks. As promised here are some tests with a dial indicator. For comparison reasons, I have made two groups of tests. The first group will be testing the ER11 adapter (I bought and used it before). The second group will be the ER11 spindle, which I was discussing in the above post.
ER11 adapter tests. This adapter is inserted on the original threaded spindle and tightened with two side set screws.
Test#1 On top of the adapter
Test#2 at the middle of the adapter
Test#3 at the end of the mill
As you can see, all three tests are reporting errors in precision. In fact, the errors are 20 hundred of an mm, for such an adapter, it is somewhat a lot. With such a tool, it will be difficult to archive precision., but it will be acceptable to even the flat surfaces.
ER11 Spindle test. This is the game-changer. You need to replace the original one which comes with Proxxon MF70. Worth every penny spent, and I am really happy with this change. bear in mind that you will need to buy good quality collets. The good thing, is you don't have to buy the whole set. Buy only the one you will use most. Example: 1.0mm, 2.0mm, 3.0mm, 1/8' (3.175mm), 4.0mm and 5.0mm. Endmills with larger shank sizes I wouldn't recommend using with this motor.
Test#1 On top of the spindle
Test#2 at the end of the mill
Now, you obviously see the difference. The dial indicators barely move, if it not moved at all. I am very happy with those tests and will expect precision milling in the near future. Here are the collets I use, I bout them here.
4.51US $ 46% OFF|Free Shipping High precision ER11 Accuracy 0.008mm Spring Collet for CNC Milling Machine Engraving Lathe Tool|Tool Holder| - AliExpress
I have great experience upgrading Proxxon MF70 and was rewarded with great results. Do you get most of your MF70?
It is the adapter causing the quill. The adapter has a bore, not a thread, and I just slide the adapter on top of the threaded spindle. It was mostly experimental.Are you able to spec the quill without the adapter? Is there a guaranteed accuracy? Or is it fully acceptable? You know, for a price, a machine shop might make a replacement. But if the quill is causing the wobble, maybe replace the bearings?
I see the collets and am guess they insert into the adapter...was thinking maybe the quill was threaded or employed a Morse Taper....if its baprely moving, then that is what you want. (And wondering if there is any backlash?)It is the adapter causing the quill. The adapter has a bore, not a thread, and I just slide the adapter on top of the threaded spindle. It was mostly experimental.
Replacement spindle is guaranteed accuracy, Phil! The spindle is turned in a stainless steel chuck and has a concentricity accuracy of approx. 0.01 mm.
No backlash, no wobble or quill. The spindle doesn't attach via Morse taper, but the ER11 system has excellent milling results when upgraded.I see the collets and am guess they insert into the adapter...was thinking maybe the quill was threaded or employed a Morse Taper....if its baprely moving, then that is what you want. (And wondering if there is any backlash?)
Yes, you got the most out of it. 5 mm. Is the max. I read that on the site of the manufactur. They have on that side also an gear to add and use bigger mills. But the price of that!!Do you get most of your MF70?
