Good one that, just a copy of the Proxxon FET (the model before the one of the first post.) I got this model of Proxxon. The new Proxxon is more precise but I do a lot with this one.How about this one - tilt capable.View attachment 336006
I have a tablesaw, a bandsaw, a scrollsaw, a proxxon ks 115, a mitersaw, several jigsaws. I bought the Proxxon for quickly cutting tiny rips that would be too wasteful on a full tablesaw. The thin blade makes a tiny kerf and while I could rip on a tablesaw, the 1/8" blade width would create a lot of sawdust.Good one that, just a copy of the Proxxon FET (the model before the one of the first post.) I got this model of Proxxon. The new Proxxon is more precise but I do a lot with this one.
Why not go for a small one like the 37070 and a normal table saw. There is so much more possible in that way. Something to think about.
Te puedes hacer una tu mismo en casa. Solo necesitas una sierra circular del diámetro que quieras, un motor eléctrico con interruptor y una mesa con una ranura y armazón. Si quieres puedo enviarte los planos, gratisHoy puedo comprar la máquina Proxxon a $ 640 dólares canadienses con entrega e impuestos (esto es alrededor de $ 470 US en este momento).
Saludos
Good day DaveYou can make one yourself at home. You only need a circular saw of the diameter you want, an electric motor with switch and a table with a groove and frame. If you want I can send you the plans, free
