- Jun 17, 2021
I greatly appreciate your replies to BMT. Great advice. Helpful to me as well. I want to see everyone in this boat happy and confident in the cruise.
BMT, I studied your photos a bit more closely and in the one with the pen level on top the shadowing suggests that the sponson tops are 1/32 shy of the bulwark top. Excellent!! Your photo was really helpful!I'm a few steps behind you on this build and I think you can help me solve some problems I created. When it came to attaching the outside upper bulwarks there was a joint amidships that I managed to glue in with a significant dip like a flattened V with the arms immediately above the slot for the sponson attachment. I noticed this problem after planking. I increased the bulwark height at that point and sanded until it looked like I had a smooth run. Now, looking at the instructions for sponson attachment, I'm not sure whether the sponson tops should be even with or 1/32nd short of bulwark height. Thoughts?
Good morning, BMT! No problem! I have found it helpful to have a couple of shipmates along for the build.Thanks for your observations …Peter had brought the deck to my attention …..I have glued some of the structures already, and I’m concerned taking them off might affect the deck. I’ve stopped, and I’m giving it some thought… I like the concept of planking it, but I may have to take a couple more items off. I’m traveling so I’ve got some time to think about it. No rush on this end….. BMT
You can probably work around most of it if you don't mind cutting and fitting miniscule planks. Probably no worse than doing microsurgery on pieces you have already installed. Either way time and patience are your best tools and I think the satisfaction you get from the results will be well worth the trouble. After all you are under no constraints. Put your own satisfaction with yourself and your model first. There's still plenty of time to tweak and do-over where you desire to get what you want.Thanks for your observations …Peter had brought the deck to my attention …..I have glued some of the structures already, and I’m concerned taking them off might affect the deck. I’ve stopped, and I’m giving it some thought… I like the concept of planking it, but I may have to take a couple more items off. I’m traveling so I’ve got some time to think about it. No rush on this end….. BMT
