**VIEW THREAD HERE** |
Hello Heinrich, a small correction (hope you don't mind), I know it is a bit confusing... The ports frames MUST be flush with the first layer of planking (hull). Its the second planking must be recessed 1 ~1.5mm from both sides, Take a look at Uwek's picture (Plan View). Top Timber Futtock, on both sides - is flush with the hull. In our case, it is a port frame. Planks have recessed both sides to make a port stop:Hi Paul. Just remember what Uwe and Mr Deep were saying. When gluing, the frames need to be recessed by about 1.5mm. They must not lie flush with the hull.
Again, you took the parts from the set.Throw them out.First, they are thin.Secondly, on a real ship, the side walls of the ports were used as frames.But they were hit from above and below by the jambs .The angle should be straight 90 degrees.I have already written about the thickness of the hull skin, along with the internal and together with the thickness of the frames.You can glue a box of slats.Then cut it into frames of the desired thickness.When gluing the frame, do not forget about the bending of the casing.The upper and lower jambs should be strictly horizontal.The gunport frames are finished and I have installed (not glued) one.
View attachment 151509View attachment 151510
