Hi,
My Rikon 10" 10-3061 bandsaw is backorder since 1,5 month and will be another couple of weeks. I canceled the order and need a good budget replacement bandsaw. I have eyes on the King Canada KC-1002C wich is 10" but at lower, so I would like to know if this bandsaw is good enough for modelism, and medium homework and resaw at scale for 10 " ?
10" WOOD BANDSAW
Michel
10" WOOD BANDSAW
- 10" Wood bandsaw with stand
- Quick release lever blade tension system
- Adjustable upper/lower ball bearing blade guide system
- Cast-iron tilting table with built-in retractable extension
- Flexible LED light increases workpiece visibility
- Rack & pinion height adjustment system
- Dust chute accepts 2", 2-1/2" and 4" dust collector hoses
- Comes complete with miter gauge, rip fence, adjustment wrench and hex. keys
- CUTTING CAPACITY FRAME TO BLADE9-1/2"
- MAXIMUM DEPTH OF CUT4-1/8"
- TABLE SIZE13-3/8" x 13-1/8"
- TABLE HEIGHT FROM FLOOR41-1/2"
- BLADE SIZE67-1/2" x (1/8" - 1/2") x 0.025"
- MOTOR1/2 HP
- AMPERAGE3.4 Amp.
- VOLTAGE120V, 1 phase, 60 Hz
- SPEED2,750 SFPM
- ASSEMBLED DIMENSIONS (LXWXH) / WEIGHT26" x 20" x 58-3/4" / 91 lbs
- PACKAGE DIMENSIONS (LXWXH) / WEIGHT34-3/4" x 15-1/4" x 18-1/8" / 95 lb
Michel
