Next I wanted to concentrate into the machinery of the boat like the boiler and steam engine.
I started with the easier of those two, the boiler. It was made of two D shape pieces of 6 mm MDF, on which a plate of 1 mm plywood was glued. I wanted to show the numerous rivets on the surfaces of the unit, typical for the boilers of that era. That was made using self adhering 0,1 mm aluminum foil where riveting was pressed with a special tool made of old alarm clock gear.
Steam dome is made by turning from piece of Sikablock plastic material, funnel is part of 20 mm thin walled steel tube. On top of the funnel a smoke generator from a company Seuthe was installed. It is specified for 4,5...6 volts and the battery on bord is a 2 cell LiPo with nominal voltage 7,4 V but the smoker seems to work fine with this voltage too
Water level glass was made of a capillary tube from an old thermometer, safety valve of styrene and pressure gauge was turned from brass and the dial designed with computer and printed on paper. Later on the boiler will be painted matt black and instruments with brass paint.
And the smoker seems to work fine:
