The HERMIONE, Scale 1/89, Artesania Latina
France, Colombes
After 2 years of work, here is the Hermione, model of the Frigate used by La Fayette to join America in 1780. 75cm long and 62 cm high. Quite a lot of sleepless nights, a lot of patience and nearly 1600 knots, as many nails, several tubes and pots of glue and paint, meters of wires, kilos of wood and some bandages for the fingers _MG_2190.JPG_MG_2191.JPG
_MG_2192.JPG_MG_2194.JPG_MG_2195.JPG_MG_2196.JPG_MG_2198.JPG_MG_2199.JPG_MG_2201.JPG_MG_2202.JPG
This a very find model - congratulations for this great model. Thumbsup
Usually, when a ship model is finished, there is already a new successor on the work-bench?
Do you know already, what will be your next one?
Thank you so much for the compliment
Yes of course the following is already being edited.
2 models are under construction: The Mare Nostrum by Artesania Latinaet the Cutty Sark by Constructo.
I never get bored and already have many other projects.
But first I have to move at the end of the year to have a workshop a little bigger as the place starts to run out
After 2 years of work, here is the Hermione, model of the Frigate used by La Fayette to join America in 1780. 75cm long and 62 cm high. Quite a lot of sleepless nights, a lot of patience and nearly 1600 knots, as many nails, several tubes and pots of glue and paint, meters of wires, kilos of wood and some bandages for the fingers View attachment 178667View attachment 178668
View attachment 178671View attachment 178672View attachment 178673View attachment 178674View attachment 178675View attachment 178676View attachment 178677View attachment 178678
Hola Silbain, te ha quedado una Hermione preciosa y muy colorida,te mando un saludo cordial y a por más modelos, que es lo que nos hace esta afición, que no parva nunca, saludos Joserra Iturriarte, joserraitu
Muchas gracias, es muy amable de su parte. Muy amistosamente
Après 2 ans de travaux, voici l'Hermione, modèle de la Frégate utilisée par La Fayette pour rejoindre l'Amérique en 1780. 75cm de long et 62 cm de haut. Pas mal de nuits blanches, beaucoup de patience et près de 1600 nœuds, autant de clous, plusieurs tubes et pots de colle et de peinture, des mètres de fils, des kilos de bois et quelques bandages pour les doigts [ATTACH = full] 178667 [/ ATTACH] [ATTACH = full] 178668 [/ ATTACH]
[ATTACH = full] 178671 [/ ATTACH] [ATTACH = full] 178672 [/ ATTACH] [ATTACH = full] 178673 [/ ATTACH] [ATTACH = full] 178674 [/ ATTACH] [ATTACH = full] 178675 [/ ATTACH] [ATTACH = complet] 178676 [/ ATTACH] [ATTACH = complet] 178677 [/ ATTACH]
Après 2 ans de travaux, voici l'Hermione, modèle de la Frégate utilisée par La Fayette pour rejoindre l'Amérique en 1780. 75cm de long et 62 cm de haut. Pas mal de nuits blanches, beaucoup de patience et près de 1600 nœuds, autant de clous, plusieurs tubes et pots de colle et de peinture, des mètres de fils, des kilos de bois et quelques bandages pour les doigtsView attachment 178667View attachment 178668
Bonjour Sylvain...un grand bravo
All I can say I wow! I seriously hope mine turns out as nice as yours! Great job! I have months of work left on mine but your work is very inspiring.
