I hope to be done within a month, including sails! Then it's Bluenose time!WOW Dean. You are going lightning fast with the rigging! ANY rigging completed, would be a major milestone to me!
I suspect that’s why they used toggles everywhere. I will get good at rigging them!![]()
Fascinating. Thanks for the detailed view of this rigging method.Progress...made shroud line pieces. It’s crazy how one line can be made of 4 separate parts and have 5 pulleys and 1 toggle!
Above are the sub assemblies needed to make the two shroud lines for one side of the foremast. They connect to the shroud pendants through running rigging.
Above are the lines done for one side...
More pics below...
View attachment 203984View attachment 203985
I’m showing the method of doing the shroud lines for anyone who may decide to build this ship. It is so different from square sails!Fascinating. Thanks for the detailed view of this rigging method.
Thanks for the full explanation.Ok after making the shroud pendants for the main mast, it was time to attach them.
they have hoops that are hooked on to the upper woolding...so I glue one end of the woolding rope, make one wrap and slide them on one side in the correct order...
then I tape them to the mast to keep them pulled down and next to one another. Then I put a dab of glue on the front and glue the rope there and then load them on the other side in reverse order (mirrored). Then I run another wrap in the loop again and glue down the end of the woolding rope.
then I add the lower woolding rope on top of them, add a little glue to hold everything in place.
Then it’s time to glue the mast in...
that done I move on to the pulleys that raise the main yard.
build them off the ship...
then I run the rope through the mast for raising the main yard, that hooks to the upper pulley. This holds the pulley assembly loosely in place while I glue the eye pins into the deck behind the mast.
now to let this dry and then I will tension the yard lines and pulley assy. This I do by hanging a weight on the end of the yard lines. At that point I will glue the lines where they go through the mast. That way when dry I can take weight off and lines will stay tight awaiting the yard assy!
Now making the rest of the pulley sub assemblies for doing the shroud lines.
See you next time!
@paulv1958Its a complex beast to rig. Requires you to re think the whole process. The spars & sails running rigging are a fun challenge. Definately Add the sails to the yards first. Due to their size and the complex mast shroud process, sewing the sails on post install will be a nightmare. Pre attached its easy to pass through and pin the yards in place. You will also need to adjust the spar angle for the sail base to sit square. This is much easier with the sail attached.
It may all be strange (I wouldn't know) but it is eye candy!Oh yeah...all lines are tied off to the railing that sits almost on the deck. So tie off points are between cannons and the line has to be fished out with hooked or bent tweezers to reach under the board and pull the line to the other side.View attachment 204818View attachment 204819
Thank you, it has been quite the mental challenge, as well as an exercise in dexterity!Oh yeah, tying them off looks like loads of fun! ;P Nice work, Dean, and thanks for the detailed view of this shroud assembly. I, for one, am really digging seeing the variant on method. Cheers!
Thanks Paul!It may all be strange (I wouldn't know) but it is eye candy!
