Pocher 1:4 Ducati Panigale S ‘Anniversario’ + ‘Final Edition
Before I get started with the next chapter, I had to make 3 banjo plugs for the 3 brake shoes. To replace the plastic ones.
So:
-flatten chrome ball with hole on both sides;
-drill hole for the brake line;
-1 mm copper wire brake line;
-the hose clamp for the brake line already put on, of 2.5 mm copper tube;
-hexa bolt from a former Pocher kit through the hole.
On both brake shoes for the front brake:
With the result:
Right front:
Links front:
Behind:
The brake hose can be put a little further on it. And a tip of paint on the hex-bolt/banjo.
So:
With the result:
Right front:
Links front:
Behind:
The brake line can be put a little further on it. And a tip of paint on the hex-bolt/banjo.
Hi Peter,
Great to see progress once more.
Great work love the banjo fittings, I hope you bled the brakes after fitting the hoses. ;)
Cheers,
Stephen.
Hi Peter,
Cheers,
Stephen.
Thanks Stephen.
Of course I do, standard procedure.
I will use this, for my race-bike. Same connection:
Nice to see more progress on the bike - keep it coming!
Ted
Thanxs Ted, here it comes:
Chapter 17-1:
In this chapter, the parts are assembled into a few components.
First all the parts collected. After that, many switches between the manuals of Pocher and Paul Koo, as well as the photos:
I'll show the components separately.
Clutch Slave Cilinder:
In addition to M1.6 x 8 socket-head Allen screws from Paul Koo, a new banje plug has also been made here.
Front Sprocket Guard:
The cylinder is mounted together with the front sprocket guard:
Front gear protection:
This consists of both a metal bracket around the gear and a protective cover over the gear. Behind this hood is the cabling of the Gear Position Sensor as an extra detail:
Left Heel Guard:
This is normally attached with 2 bolts to the main bracket to which the rear spring system is also attached. The model is missing the 2 bolts. Therefore 2 holes 1.3 mm drilled and 2 Allen bolts attached:
Soon we will continue to assemble many parts on this main bracket.
regards, Peter
Left Footpeg / Gearshift Lever:
Extra’s:
-Instead of a black Philips kit screw, a Paul Koo socket screw is used for the footpeg.
-The gearshift lever should also be installed with a black Philips screw, inside the hole of the main bracket.
The pivot hole in the bracket is enlarged with a 2.5 mm drill. The pivot hole in the gearshift lever is enlarged with a 2.3 mm drill. After use of a M2.5 tap, the lever bolted with a button head Allen screw.
Rear suspension and Quick-Shifter:
The parts:
Installed with the decals. And work a little ahead to assemble:
Spring and Shock Forward:
All together:
Peter,
Excellent build log - That is one heck of a superb kit - I knew Pocher from their cars - didn't know that they were still creating new kits - You're doing
a great build....
Regards,
Peter,
a great build....
Regards,
Thanxs John,
Since a few years they do. Bikes and hopefully second half of this year: See my post 75, with the link for the new Pocher Lotus 72D.
Pocher is now part of Hornby Hobbies. Perhaps the reason for the development of this British icon of Colin Chapman.
Wow!!!,
My Admiral is Brazilian - met her there years ago when I was going back and forth a lot, we became close - Been together forever.
BUT we had a mutual friend, living in Marina del Rey CA, who knew him very well. He happened to be in Los Angeles when I was alo in LA; the three of spent a great evening with him. Charming, and funny - Though when he won the Indy 500 fans, and the press were a bit more than upset (Milk vs Orange juice)
I may just have to get that kit when it is released. Thanks for the head's up - missed that going through your log
Cheers,
Wow!!!,
Cheers,
John, what a beautiful story!
It's great that a build log triggers these kinds of memories.
An advice: make a pre-order. There's (as mostly) quite a limit and there's a lot of interest.
The last component of this chapter 17-1.
Kickstand:
With the spring and the wiring for the drive-protection.
Rear Cilinder Side Cover:
Before mounting the rear shock absorber support, PK recommends that you install the rear cylinder side cover on the left. It now stands with me that by the previous Duc it was indeed the puzzle. The flange must be under the rear frame and 2 pins in a recess:
Chapter 17-2:
The support with shock absorber and kickstand mounted:
With the details:
A: the attachment to the block;
B: same, together with the kickstand;
C: Suspension / shock absorber link system;
D: hinged shock absorber arm;
E: Quick-shifter;
F: Kickstand + road safety, with the cable to the connector;
G: Wiring Quick-shifter and gearbox position sensor, held together with pieces of heat shrink tubing;
H: hose to clutch slave cilinder;
I: 2 hoses of the adjustable shock absorber;
J: Rear suspension Rocker Arm between swingarm and link system. This is in the 'low/street' position:
'High' is for circuit use. Then the Duc is more ‘on the front suspension’.
The Duc can now stand free, without a temporary block between the rear frame and the swingarm.
And I could adjust the chain right away.
The whole now weighs 5.2 kg.
With a functioning:
Kickstand:
Rear suspension:
Shift pedal with Quick-Shifter:
Time to do something on The Duc.
Chapter 19:
Left Handlebar with Clutch:
All the parts with my fingers as a reference. The spring in the bag SP-05 is very tiny.
But also the decals, some with the size of the tip of a toothpick.
The parts for the hand lever/clutch parts:
Fitted together:
With the decals:
And the extra’s:
-most of the bolts where from the Paul Koo kit;
-1: cable from the height-control switch for the electronic suspension;
-2: cable from the switch unit;
-3: rubber washers;
-4: gray paint on the center button and height-control switch;
And the reservoir cup filled with flued.
The end of the handle bar painted black.
In the middle below, the connection for the cluch-tube.
