I am building the African Queen. I have built 2 small ships previously. Both were solid hull and neither used wood strips. This model requires decking be glued over a false deck. I have "Ship Modeling Simplified" by Frank Mastini and "Ship Models from Kits" by Colin Riches. I can't find any reference to the issue I'm having.
My problem is that all the planking provided, have in varying severity, what are called "crook" and "twist" deformities. Some of the deformities are so severe that there isn't even a 3" length which I could salvage. I have seen this in other tall ship models which leads me to believe it is common.
Is this a defect in the kit and I need to contact billing for replacement??
Or am I supposed to reform the strip by soaking in water and then pin them in a straight jig or similar method?
I considered recutting into straight strips. But that would make much narrower strips and it would be difficult producing a uniformed width on all strips.
I could cut off the deformities on the least severely deformed strips, but that is a lot of wasted wood. I'm not confident I would have enough left to finish.
Thanks in advance for your help. I'm attaching a photo of the strips. I added a straight edge for reference.
