which material are the tubes?I have searched for tube bending but cannot find any posts on the topic. I considered using water and detergent or water alone and I know there are other techniques. Which technique works best?
bend very slowly in stages,,,, the sand will keep it from collapsingfill it with sand
3mm OD brasswhich material are the tubes?
Should I cap each end to keep the sand in?bend very slowly in stages,,,, the sand will keep it from collapsing
I dont know.... I was just guessing... seemed to make sense....Should I cap each end to keep the sand in?
That's funny! LolFind a piece of solid brass rod the same ID as your tubing. Insert the rod in the tubing and bend away! (Then try to figure out how to remove the rod! LOL!!)
I wont build any more models that will have bent tubing so the tool will just sit. And Billing provides a length of electrical wire of the same diameter that is covered with black cloth. It simulates wrapped steam pipe. So if I totally screw up I can use the wire.What diameters are you considering? There are springs you put the tubing in before bending. I bought the Micro-Mark bender primarily for bending wood but it also has grooves for roller bending smaller tubing. Anything much larger, you can use a tubing bender.
Less expensive way:3mm OD brass
Straighten the tube up to get the brass bar outFind a piece of solid brass rod the same ID as your tubing. Insert the rod in the tubing and bend away! (Then try to figure out how to remove the rod! LOL!!)
If you anneal the brass rod beforehand, you can probably remove it from almost all curves. Heat until red with a propane torch.Find a piece of solid brass rod the same ID as your tubing. Insert the rod in the tubing and bend away! (Then try to figure out how to remove the rod! LOL!!)
