Thanks for your advice. Turned out looking good. Could have done better on the windows. Your log will be of great help. First time I will paint the model. Any reason I shouldn’t paint the waterways before installing them?On my Rattlesnake I started with breaking apart the kit white metal transom decoration into three pieces. The middle piece, the actual rattlesnake, I I gilded. The other two flanking pieces I sprayed with primer then a base coat of black. Then I just gilded the raised portions of the two flanking pieces. Easy peasy lemon squeezy.
What process did you use?Thanks for your advice. Turned out looking good. Could have done better on the windows. Your log will be of great help. First time I will paint the model. Any reason I shouldn’t paint the waterways before installing them?
Primed the metal, painted it black, sanded the high spots then painted with goldWhat process did you use?
