**VIEW THREAD HERE** |
Cheers Heinrich. The pale colored single blocks I did have. Artesania product. The black dead eyes and the blocks for the forestay are my attempts. I am happy still loads to improve.Very nice and taut bowsprit rigging Grant. Your self-made block looks far better than the majority of factory-manufactured products!
Very tidy work Grant, the bowsprit is for me one of the most attractive parts of a sail ship. I think you need to add a few scratches or chips to your work though as your neatness is starting to show us up now ...Thanks guys. Continuing rigging the bowsprit. I added the boomkins(per kit), made the toilets from a photo (don’t know why this section of this ship is not called the “poop” deck) and made one of the dead eyes for the forestay connecting to bowsprit. I also connected the bowsprit shrouds to the hull.View attachment 271762View attachment 271763
The forestay is connected via a block more than a deadeye as shown in the instructions. For this I used a 7x4x2 mm wood drilled a 3mm hole and shaped with needle file. I served the rope to hold this as well.
Hi Heinrich. Agreed- going to have to do some research and see what I can do. I don’t like them and I’m sure the ship architects did not just bang a block there.Hi Grant. The little platforms and ladders look fantastic, but I share your doubts about the blocks as top step. But then, I know too little about how it is done on other kits of Victory to really venture an opinion.
It does appear soBut hang on - then the Mantua kit is correct! That is clearly just a block sitting on top of the "platform".
Sounds greatMaybe it is just a block but I think it would look better with a 'tread' on it with a bit of overhang. Might need to sand down the 4x4 to allow for the additional height. I would use the thinnest strip veneer you have (0.5 - 0.7 mm max).
This is what the sirens sound like...
I suspect the 4x4 block was a simple approach at a single step without using a frame. Furthermore, an overhang would most likely be a tripping hazard… as it’s more likely you would catch your foot on it, as ships at sea tend to move around a lot.Maybe it is just a block but I think it would look better with a 'tread' on it with a bit of overhang. Might need to sand down the 4x4 to allow for the additional height. I would use the thinnest strip veneer you have (0.5 - 0.7 mm max).
