Using a pin vice to drill a treenail hole is simple enough, but I am having a problem with holes that will be seen from both sides. I am struggling to keep the drill vertical (horizontal). I have thought of a drill press for my Dremel, but I am using bits that are too small for the chuck, and I doubt that a bit of .5 mm would survive even the lowest speed. I would appreciate any tips on how to keep my pin vice vertical. My current issue is a cathead where four holes on the top need to emerge on the bottom with a similar spacing and pattern.
