Progreso del Revenge de Occre
Primer forro del Revenge
[ATTACH = completo] 256631 [/ ATTACH] [ATTACH = completo] 256632 [/ ATTACH] [ATTACH = completo] 256633 [/ ATTACH] [ATTACH = completo] 256630 [/ ATTACH]
trtre
Hallo @Gravina
I will follow your build with big interest
As we can see on your first photos - you made a very good basis for the second planking with the first planking and filling works.
Which scale has this model?
Hola Uwek. La escala es 1:85. Iré subiendo fotos de mis progresos. Nice to Meet you!!
google translation:
Hi Uwek. The scale is 1:85. I will be uploading photos of my progress. Nice to Meet you !!
Otra paso más. Concluido el timón. Empiezo con los pasamanos y barandillas. Es una fase más larga y delicada que dejaré para el fin de semana...
Another step. Helm completed. I start with the handrails and railings. It is a longer and more delicate phase that I will leave for the weekend ...
Looks great, following with interest so keep the posts coming.
Concluidos todos los balcones del castillo, alcázar. El cortar tantos pilotes de 3 * 3 de 13mm de altura perfectamente a escuadra ha sido un reto. Cuanto más avanzo en esta afición, más me doy cuenta que además de habilidad hay que contar con la herramienta adecuada para cada paso. Lo siguiente será colocar cintones y las decoraciones de cartón en la parte alta del casco (que en este modelo son muchas). Posteriormente barnizaré y pintaré de blanco todo lo que me señalen las instrucciones.
Completed all the balconies of the castle, fortress. Cutting so many 13mm high 3 * 3 piles perfectly square has been a challenge. The more I advance in this hobby, the more I realize that in addition to skill, you have to have the right tool for each step. The next thing will be to place belts and the cardboard decorations in the upper part of the helmet (which in this model are many). Later I will varnish and paint in white everything that the instructions indicate.
View attachment 268771View attachment 268772
Looking great, you are doing a very good job.
Se ve genial hasta ahora, estará interesado en ver qué haces a continuación con los colores y decoraciones.
Si te soy sincero, me da bastante miedo arruinar todo el trabajo hecho hasta hora....
Como conseguiste recortar las decoraciones exactamente a la medida??, alguna recomendación?
I made blank paper templates first so they would fit in between the strakes, then used that as a pattern to cut the decorations using a new blade to ensure the cleanest cut, it still required a few redos to get it as good as I could.
