Generally, Corradi is one of the trusted brand names made high-quality files. You have mentioned the Needle Files Extra Quality - 7.1″ - Luthiers' special set of 12corradi files 12 extra quality 7.i inch lutier set for about 100 dollars cnd would that be a good set to get
Yep! That’s the set. That size would be perfect for me as I rarely work in scales smaller than 1:32, or occasionally 1:48.You mean this set?
I actually would look for some quality files with smaller cross section for work I do. I work in 1:100 scale and 6 mm wide section files Corradi offers in this set are way to large. Unfortunately I was never able to locate any quality needle files of a smaller section. I tried many times buying smaller section files on Amazon but every time I got some low quality garbage.
Obviously, the shipping charges are killers. But you don't have to buy directly from Italy, There should be Canadian distributors. Also, there are other good-quality needle files branded as Vallorbe Glardon (Swiss-made). Check out the local Jewelry stores, usually, you can find those there. They might be more expencive. Very good article about the needle files, IMHO. Check it out...CORRADI shipping charges to Canada are 51 EURO. Minimum order would be CAD 225 x 1.03 = CAD 232 incl. euro conversion rate. I am out.
