Hello everyone I just bought this piece of cherry it is for a navy board model, it is 2 1/4" thick x 12 inch wide x 4 foot long , it will be used for the frames (hull) was looking to get some options on how I should go about resawing this, frame thickness is 9/32 or just over a 1/4 , thank y
I need to know, what equipment do you have access to? Or are you asking what sizes you should choose to resaw? I will be doing the same thing this summer, for the same purpose, resawing wide cherry to build a model ship but I have all the necessary equipment.Hello everyone I just bought this piece of cherry it is for a navy board model, it is 2 1/4" thick x 12 inch wide x 4 foot long , it will be used for the frames (hull) was looking to get some options on how I should go about resawing this, frame thickness is 9/32 or just over a 1/4 , thank you
Hello Greg I have a 14inch delta band saw & full size table saw , it's just that this is my first navy board model & I don't want to screw this up, I can get the radius of the futtocks (frames) out of the 2 1/4 thickness, so I'm thinking I should ripp the pieces at 1/4 strong & send through sander, thank you for your timeI need to know, what equipment do you have access to? Or are you asking what sizes you should choose to resaw? I will be doing the same thing this summer, for the same purpose, resawing wide cherry to build a model ship but I have all the necessary equipment.
I think your plan will work well. Just be aware of the grain but it does sound like you will be working with the grain and you have an allowance for sanding.Hello Greg I have a 14inch delta band saw & full size table saw , it's just that this is my first navy board model & I don't want to screw this up, I can get the radius of the futtocks (frames) out of the 2 1/4 thickness, so I'm thinking I should ripp the pieces at 1/4 strong & send through sander, thank you for your time
Thank you for your time I appreciate itI think your plan will work well. Just be aware of the grain but it does sound like you will be working with the grain and you have an allowance for sanding.
You are welcome. I enjoyed sharing ideas with you.Thank you for your time I appreciate
Hello KurtStep ONE.
The PLANHello Kurt
I have enjoyed reading some of your submissions so I'm glad you joined this conversation. Perhaps you could expand on your statement of "Step ONE".
Thanks for your reply.The PLAN
Step One: obtain wood.
Step Two: build ship model
Step Three: profit
Beautiful plank of cherry you have there...
It was not meant to be shouting. It was a simple joke.Thanks for your reply.
He did only ask about his idea for resawing, so that is what I shared my thoughts on.
Since you are using words in all capital letters that indicates you are shouting at all of us. I will no longer reply to you.
Enjoy your evening
Greg
Good Morning Lou, Thanks for your re-sawing thoughts. I would probably do the same as you for ease of handling, since it does not appear Bird needs 48" lengths.Greg, I think you reacted a bit quickly, I think you will find that we all are all a pretty reasonable bunch, stick around and get to know a few of us. BTW - just for info, if you run into a post from donfarr it will be in all caps also, not because he’s angry but because he is 83 and has a hard time reading lower case letters. But he loves ship modeling and being part of a group of folks that love it too. Ask me how I found that out!
If I were re-sawing that board my first cut would be to cut it in half so you are working with 24” slabs instead of 48” and proceed as Bird outlined.
As mentioned by others, consider milling it down a bit before resawing. I'd rip it lengthwise in half. Question: does your bandsaw have the riser block installed? Next - the blade. Use carbide tipped bandsaw blade for resawing if you can. It'll be easier to resaw with. This saw has the riser block installed and a resaw blade installed also.Hello everyone I just bought this piece of cherry it is for a navy board model, it is 2 1/4" thick x 12 inch wide x 4 foot long , it will be used for the frames (hull) was looking to get some options on how I should go about resawing this, frame thickness is 9/32 or just over a 1/4 , thank you
