Good morning Heinrich. Thanks- your system worked for me and I am happy how they look. They don’t take too long either which is a plus for sureThat looks simply brilliant Grant. Well done, young man!
I haven't moved yet!Good morning Heinrich. Thanks- your system worked for me and I am happy how they look. They don’t take too long either which is a plus for sure. You mentioned (I think in Ron’s log) that you are closing your shipyard for a while- are you moving again?
Hello Daniel. Yep you are correct.....Eish. All my dead eyes can still rotate so I am hoping that when I do line them up when doing the lanyards all will come right. I completely forgot to do this when doing the shroud attachment. Tomorrow morning I will check in mean time I hold my breath...Grant it looks like you have a very good system for dead eye alignment. However, judging from the skew lines on the board, you may need to adjust the chain strop on the bottom row of dead eyes to get a line matching closer to the ones on the temp backer board. At the same time you could pull some of the slack out of them as well.
Hello Heinrich...the method is good- other modelers who use this did wonderful deadeye to shrouds. The jury is still out here tho. CheersI said it earlier - sensible and methodical. It has to work - good work Grant!
Buon pomeriggio, potrebbe essere utile anche questo sistemaCiao, Daniel. Sì, hai ragione..... Eish. Tutti i miei occhi morti possono ancora ruotare, quindi spero che quando li allineerò quando faccio i cordini tutto andrà bene. Mi sono completamente dimenticato di farlo quando facevo l'attaccamento della sindone. Domani mattina farò il check-in nel frattempo trattengo il respiro...
Saluti
Thanks Paul. It been fun, a model learning and character building experience. Mostly I just love spending time in my shipyard tho. CheersGrant, great job!! incredible detail
Hello Frank- I did consider that system, however I felt that it left chance for variance from the line direction of the shrouds. I think a more experienced builder would have the confidence to do this or even judge it visually. I just need to be a little conservative in my options as I’m learning. CheersBuon pomeriggio, potrebbe essere utile anche questo sistema
Hello. Yes that is strange. Mathematically this should not happen if the measurements run correctly. Your channel appears in line so I don't have the answer for that. I have not seated the mast yet as I need to wait for some new blocks, however on a simple test run, these seem reasonable. When I tension the lanyards it looks like it will come out good. Holding thumbs....still a way off tho.I used same method just in smaller scale, but fore some reasons last three deadeyes were under fixing points and i had to readjust them - much above orginal line. Maybe somebody knows why it happend. Red dots mark place before readjusting
Buona sera , secondo me per aiutarti tantissimo sul Tuo modello dovresti procurarti questo libroUn'indicazione storica è che questi quartieri Davits non erano sul Trafalgar Victory. Questi arrivarono molto più tardi intorno al 1806 (si stima). La prova effettiva di queste gru è documentata solo nel 1864. Tuttavia ci sono disegni di Christian
Schetky nel 1824 che mostrano questi. Quindi fai la tua scelta.
Le gru di poppa (che ho anche intenzione di realizzare) furono installate solo nel 1920.
La mia povera Vittoria ha un po' di questo e un po' di questo come accuratezza storica.
Ho intenzione di appendere due dei lanci a questi ed è per questo che voglio ottenere il sartiame corretto.
Saluti
