Hermione Lafayette
Planning to do a good push through x-mas to close the hull. I’ve got some issues with finding the correct color for some of the details but it will solve it selves I belive
Thank you for sharing your first build with us, If you type the name of your ship in the Search Block, I am sure you will find previous build logs and some ideas about color combinations and the like. The replica ship should also be a great help.
you are on a very good way - Have fun and post here about your progress as much as often - we are interested and love to see photos
Whole lot of clamps…. Need to get some CA glue tomorrow… too much of a waiting game pr. plank….
Gap on both sides is getting smaller. Looks straigth on both sides. Will be needing some filler on the hull either way but what to use as litle as possible
So….. have planked 99,43% of the hull now. Started to do just a rough sanding with 80grit just to see how it turned out
Is it double planked or a single planked kit?
If double .......
definitely you reached an important point - the fun can start (after the sanding)
If double .......
It’s a single planked kit. So in accordance with instructions it needs som filler and then its into paint Looking forward into all of the smaller bits and pieces to be manufactured in near future
BTW: How is your progress on the Hermione going?
Are you still working on this model? So maybe you could make an update of your log...... would be great
