I have used CA for many years and never had a problem with gluing my fingers together. But there would be times when I could not get two pieces of wood to hold using CA. Don’t understand why. Is this is what accelerator is used for?
**VIEW THREAD HERE** |
PVA doesn't do well on oily woods either. Typically glue joints are wiped with acetone before glue up. I've done a lot of work with Cocobolo, Teak and Rosewoods this way.What kind of wood? CA will not stick to oily types of wood.
i have used opened CA glue that is a year old and it still works just fine
If you put piece ofI have used CA for many years and never had a problem with gluing my fingers together. But there would be times when I could not get two pieces of wood to hold using CA. Don’t understand why. Is this is what accelerator is used for?
If you put piece of wax paper between wood and finger to hold together ,it will not stick to fingers
can you please provide documented proof? I have read sites on CA properties and found it to still be intact after 40 years.CA glue is OK for temporary (less than ten years) use. It will become brittle and may fail with age. CA should be backed up with tenons or pins. I recommend mini treenails from black locust made with a wire draw plate. CA is handy stuff, but you should think a bit about each and every place you use it.
CA sets up by moisture. IanC has it right - the commercial accelerators are basically moistening agents. You can accomplish the same for free with a brush and (distilled) water; merely slightly moisten the wood. This is also why CA sets up in the container. The air at the top contains atmospheric moisture and ruins the glue. If you store the bottle or tube upside down, the bottom sets up, but the glue at the (now inverted) top will keep much longer.
1. I would think the problem is with Mercury as a supplier and not with his age. Try Satellite City (amazon.com).Here is CA I bought less than a year ago. Checked yesterday. It doesn’t set on wood anymore.View attachment 292031
