Well Heinrich, after my discussion with the Admiral this morning I took a ride to one my favorite spots and contemplated her “logic”Looking good Jan! Are you going to plank the whole deck or partial (like Piet has done)? Just thinking that if you do not plan on installing cannons, there is no need to plank the whole deck. You can add two or three rows on either side of what you have already done, and then that is enough!![]()
Perhaps a second donut would add some clarity...Of course you are nuts - so am I and so are many of us! But now you have to take the logic further. Scribing the lines without cutting out the ports is what you SHOULD do - that is why that would be logical. However I messed up and - according to yourself so did you. In my case, I cut too deep to salvage it, so I had no other option but to cut them out, You however, can try again! Or you can cut them out and place cannons like I showed you, in which case you avoid being monkey food. But seeing that you said you are not going to install cannons, that would not be logical either.
And should the second attempt at scribing not work either, then the illogical becomes the only option - which - would then make it logical!
So, to sum up - fancy another attempt at scribing?
Just indigestion, Paul!Perhaps a second donut would add some clarity...
I guess it comes down to degree of "NUTS", I have to admit it was great comment on the Admirals part. Your postulation sounds like "Spock" on Star Trek. "So the illogical has to pass the test to become the logical whether "Nuts" or notOf course you are nuts - so am I and so are many of us! But now you have to take the logic further. Scribing the lines without cutting out the ports is what you SHOULD do - that is why that would be logical. However I messed up and - according to yourself so did you. In my case, I cut too deep to salvage it, so I had no other option but to cut them out, You however, can try again! Or you can cut them out and place cannons like I showed you, in which case you avoid being monkey food. But seeing that you said you are not going to install cannons, that would not be logical either.And should the second attempt at scribing not work either, then the illogical becomes the only option - which - would then make it logical!
That's the plan. But I need a better way of doing it. I'm going to cobble together some planks of the right dimensions and see if I can figure out a better way to do it than using a ruler and a #11 blade. Eyesight and not so dexterous fingers are the major problem.So, to sum up - fancy another attempt at scribing?
Absolutely, as you can see we of the great minds being certified as illogical - logical "NUTS" think alike.Perhaps a second donut would add some clarity..
Oh No!! A "Boston Creme topped with Chocolate donut", fresh out the kitchen. I can't describe how good those are.Just indigestion, Paul
Hello Guys...after reading this thread, the conclusion arrive- you guys are nuts.Oh No!! A "Boston Creme topped with Chocolate donut", fresh out the kitchen. I can't describe how good those are.![]()
Pot, kettle, black?after reading this thread, the conclusion arrive- you guys are nuts.
Thank you for that bit of advice.The door came out beautifully _ I cant wait to finish mine as well. Tip - do not yet glue it onto the stern. Benefit of hindsight that I can pass onto you.
Indeed, I think we are certifiably nuts albeit with a sense of humorHello Guys...after reading this thread, the conclusion arrive- you guys are nuts.. Lovely spot Jan and those donuts sound superb. Cheers Grant
I don't think there is an Asylum large enough to hold all of us.Pot, kettle, black?![]()
Thank you for the compliment. It is a pleasant spot to sit, enjoy the sounds of the waves, watch the seagulls, walk the dog or just sit and think. I’ve spent many a happy hour sitting there perusing WB builds on SOS, Dutch and French model ship forums. I hope my humble efforts will be as good.You are doing a great job on your WB Jan, beautiful place to think it over as well, there on the beach
I think there is. It’s called SOSI don't think there is an Asylum large enough to hold all of us.
