Removed
Phil- That is really good!Build Log: Nuestra Senora del Pilar (OcCre)
Update.
The stern/castle/quarters are coming along. I had installed 3 little lights (windows/ports) as instructed by gluing to the external bulkhead. I decided I didn't like the look, so I removed them, carved out openings for all three, painted in the interior red, then re-glued the windows on place. Also added the upper castle windows, molding around the windows (because to me the flat brass etchings just didn't look right) and added gold and blue paints. I left the half-round moldings coming off the back a little long so as to be able to miter in the cross pieces once I get there.
I also painted the long moldings down the sides with Watco Danish Oil (Natural) to darken them. Some of the plans show them painted yellow, some show them painted gold. I'll leave them natural Sapele.
Will start on the starboard side tomorrow, doing the same thing as the port side. Then will add detail and structure to the stern.
Pictures of my progress are attached.View attachment 303841View attachment 303842View attachment 303843View attachment 303844View attachment 303845View attachment 303846
.....and the toolsYou're right! I can expand though - have to move stuff around....(I have the room)View attachment 303944
Hello Phil. They would not only fit but I think would look better if you could shorten them. Maybe make the top railing thinner and take a tiny bit off each Pilar top and bottom- like a shaving? I’m not sure so much work would reap the reward tho. Cheers Grant
I agree with Jimsky that the feet must not be in the air. I like this idea because it will give added depth.Hey, what do you think if you cut them in two halves and use the half only, This way they will look a bit smaller (the actual ones are a bit oversize, IMHO). Also, this will make the 'foot' stays on the even surface instead of extending in the air.
One more suggestion, if you don't mind, make a curved molding on top of the windows, this will also be the floor for those pillars, It should add to the windows and make the pillars foot stand on.I am already sanding the backsides to do just what you suggest. I'll sand them down with a rotary tool before installing. Great idea!
It will have a curved molding to help support. See this picture of the port side.One more suggestion, if you don't mind, make a curved molding on top of the windows, this will also be the floor for those pillars, It should add to the windows and make the pillars foot stand on.
