Ah, those old bonesGood evening Heinrich....Thankfully not....I think Going for a spin on MX track would not be a good idea anymore
) on the Mizzen stays. No wonder I run out of thread
.Grant, your caged part is much thicker than the stay itself. From the mousing down the step also slandered. 3 inches if I'm not mistaken. Convert to your scale. The mousing blank is put on the stay, and then the mousing itself is woven. Drill a hole in the workpiece with a diameter slightly larger than the diameter of the stay. Put the workpiece on the rest of the mast (toothpick, needle file) and insert this design into a screwdriver, drill, drill machine. Give the desired shape, similar to a pear.Good morning. I am over blocks. So started on the Main stay. I gave making the mouse the proper way a go:
I don’t have clay or any turning tools so used some needle files and sandpaper to shape the internal base from a left over walnut dowel.
A couple of mistakes I picked up too late: the internal base should be more angled as per arrows. My first weaves just followed over under pattern however they should be a basket weave.
Served the mainstay and made the loop.
And here is the squeaky little fellow:
Blue arrow- stay will be seized below the mouse. Red arrow - the weave pattern was out. These while not perfect are sooooooo much better than the previous rats nest I made. I now have to redo the mouses’ (mice![]()
Cheers Grant
Hello Sahsa. Thanks for these steps. With me it is a bit of trial and error. Yes I will redo this one and I did notice the shape incorrect. I am just happy that I believe I can make these and even this practice one came out better than my previous. I do need to buy a magnifying glass and holder. It is rather hit and miss sometimes without. Cheers GrantGrant, your caged part is much thicker than the stay itself. From the mousing down the step also slandered. 3 inches if I'm not mistaken. Convert to your scale. The mousing blank is put on the stay, and then the mousing itself is woven. Drill a hole in the workpiece with a diameter slightly larger than the diameter of the stay. Put the workpiece on the rest of the mast (toothpick, needle file) and insert this design into a screwdriver, drill, drill machine. Give the desired shape, similar to a pear.
Hello Heinrich. See my reply to Sasha. Yep I am happy I can make these. My trial one showed what I have to do to get them right. It did take a while however was fun seeing what to do and what not. Cheers “redo Tyler”That little task awaits me in the not-too-distant future as well. As Sasha said, it has to have more of a pear shape, but I will keep my mouth shut until I have tried doing it myself. In the meantime, your effort is commendable my friend!
Grant, of course, will get better each time. When I was building the "Phoenix" brigantine (link in my signature) by trial and error, I wove a dozen musings. As a result, the smallest was on the stay 0.6 mm, and the largest on the stay 1 mm.Hello Sahsa. Thanks for these steps. With me it is a bit of trial and error. Yes I will redo this one and I did notice the shape incorrect. I am just happy that I believe I can make these and even this practice one came out better than my previous. I do need to buy a magnifying glass and holder. It is rather hit and miss sometimes without. Cheers Grant
Another do-over coin to you Grant.Hello Heinrich. See my reply to Sasha. Yep I am happy I can make these. My trial one showed what I have to do to get them right. It did take a while however was fun seeing what to do and what not. Cheers “redo Tyler”
. Cheers Grant
Now you have to know how to weave as well? Is there no end to the number of skills you have to acquire for this ship modelling larkServed the mainstay and made the loop.
Good morning Paul....and I thought sirens where beautiful..... I can see some challenges ahead- I have to significantly reduce the size of the trial mouse and then the weaving will be exponentially more intricate. My smallest thread is 0.2mm which I think is also too large. Thanks guys I appreciate it massivelyYou know you've entered a new space in the hobby when your 'friends' become the sirens...![]()
. My friends the sirensGood morning Mark- your turn is comingNow you have to know how to weave as well? Is there no end to the number of skills you have to acquire for this ship modelling lark
I don't know much about mouses/mice so can't comment there but the serving of your mainstay looks spot on Grant, very tidy. I can also see why you'll be needing a lot of thread for your rigging![]()
. These little rodents are a challenge for sure. Cheers Grant
).These will be tiny for the Mizzen top stay for sure.
Thanks Tobias. Been a fun ride of learning for sure. Interesting hobby this for sureVery nice, Grant. You've done a really great job with your Victory so far, very impressive.
I could look at these images for ages, beautiful,Good morning. Over the past while, when I was “over” rigging my Mizzen I added blocks and shrouds to the main mast. An absolute pleasure doing these with mast not seated. Even made some unusual double blocks for the top mast without calling my Victory any inappropriate namesHere are some pics.
View attachment 314383View attachment 314384View attachment 314385View attachment 314385View attachment 314386View attachment 314387View attachment 314388
I was chuffed that my mast mods worked an everything fitted. Not 100% accurate however a significant improvement from the kit with resources available.
Cheers Grant
