ROFLor it is a mill wich you destroyed ....
Agrre with this hypothesis too, but the size of the ball must be known accurately to deduce the distance from the edge.By the way a CMM is a Coordinate measuring machine.
You don't take measurement with a Proxxon MF70. So this is not a probe to take the measurement in mine opinion.Agrre with this hypothesis too, but the size of the ball must be known accurately to deduce the distance from the edge.
My wag(wild ass guess) is that it is used to zero the Z axis? or my second guess is that it doesn't belong on the Proxxon machine at all... lolGreetings folks! That is me again, talking about Proxxon MF70 (hope you are not tired).This time, before the actual tutorial, I'd like to make a little quiz and see the responses. If you don't know, just do your best guess, the tutorial will follow shortly, in a few days...
Don't forget to vote!!! Good Luck!!!
View attachment 320250 View attachment 320251
Oh...no...but it's worth trying.Is it a ball burnisher?
Um...shape a polymer clay...I may try one day, mon ami.Looks to me something to shape polymer clay.
Or to burn wood when used in the mill also to polish like a PCD ball end mill
bingo...but no cigar...A worn out old ball-end mill with special rust stain effects found in an old barn off a highway somewhere around Brooklyn.
You guessed it correct, Jack! It is nothing to do with just a Proxxon mill and could be used on any mill, perhaps. Also, I like the way you think about the 'zero' axis.My wag(wild ass guess) is that it is used to zero the Z axis? or my second guess is that it doesn't belong on the Proxxon machine at all... lol
Well, Algo, you hit the nail on the head...Is it used to ensure that an object is setup correctly, I.e. level or parallel?
Greetings Stephen, you guys are solid rocks when it comes to machinery and its use of it.Hi Jim,
Great little teaser.
I would say it is a probe for a CMM.
In your Proxxon you might use it for an edge finder and if you got really tricky with the help of a multi meter it could help ensure a higher degree of accuracy.
Then again I could be way off the mark.
Cheers,
Stephen.
Oh no...I am not that good, wouldn't shape so nice destroyed endmill, but I may try...I am with Stephen - in german we say "Kantenfinder" means "edgefinder"
this answer from Kill Drill himself...or it is a mill which you destroyed ....
Upps .... I am very experienced in thisthis answer from Kill Drill himself...![]()
There you go. Now I think I should go buy a lottery ticket. I seem to be having some good luck today. lolYou guessed it correct, Jack! It is nothing to do with just a Proxxon mill and could be used on any mill, perhaps. Also, I like the way you think about the 'zero' axis.![]()
LOL I use a broken mill for that.Well, Algo, you hit the nail on the head...
