Is it not an option to buy in the USA?Unfortunatly, it is not available for Canada. I envy you.
sorry for silly question, but can it be used for small wooden items such as for making stantions etcI used to own a 230, sold it and purchased the 250, which is based on the 230 design but with a lot of improvements (e.g. the 3 claw chuck and collets).
Accessories which I definitely recommend are Proxxon parts 24026 and 24024 allowing fast tool bit swaps.
I tend to use the lathe on copper, brass and Aluminium.
If possible I try to stay away form steel. To process steel properly one better should use cooling fluid to do a proper job en I find that too messy on such small lathe.
I prefer the Proxxon over a bigger lathe because the weight and size allows it to be stored away when not in use.
Thanks, I verify the price and wow, after currency exchange, shipping and duty it cost a lot of money. Oh I forget to say that I have the DB250 version, I have new bearing that require to be install in a near future to increase stability of the vertical axe (vibration or distortion). Honestly, I just miss a tool support, but the conversion is too difficult for me and I have no easy solution for that transformation.Is it not an option to buy in the USA?
Precision Lathe PD 250/E
For face, longitudinal and taper turning, thread-cutting. For machining steel, brass, aluminium and plastic. Mounting flange for fastening the mill/drill head PF 230. Centre distance 250mm (10"). Swing 70mm (2 3/4"). Height over cross slide 43mm (1 11/16").NO 34 002 See full description...proxxon-us-shop.com
Hello, this has been my car for about 35 yearsThanks, I verify the price and wow, after currency exchange, shipping and duty it cost a lot of money. Oh I forget to say that I have the DB250 version, I have new bearing that require to be install in a near future to increase stability of the vertical axe (vibration or distortion). Honestly, I just miss a tool support, but the conversion is too difficult for me and I have no easy solution for that transformation.
www.fluidonline.de
One electrician told me in 2017 that I cannot use in Canada the EU std. But I found this morning this canadian web site : https://voltageconverters.ca/collections/voltage-converters-ult-seriesAbout the PD250E pricing.
Proxxon is a German brand and best prices you can usually find in Gremany.
Dollar and Euro have almost an equal value these days.
If it's worth it one might consider of importing one form Germany. Take into account however that the unit will be 23OV then.
But the price difference is more than remarkable.
PROXXON 24002 Drehmaschine Präzisionsdrehmaschine PD250/e
PROXXON 24002 Drehmaschine Präzisionsdrehmaschine PD250/e - am Lagerwww.fluidonline.de
