I was also impressed by the simplicityGreat jig and simple to make. Many thanks for sharing, Steph.
...there are many ways to rip thin strips. They all use the fence in one way or another, mostly the fence has to be moved each time a new strip has to be cut. The above jig allowed to set the fence once and cut as many stips as the wood stock size permitted. Also, the way it works, the cutting material is stay firm in the jig, so there is no accidental movement this is why the thickness of stips are identical in size.Well, I must be missing something here. Can't you get the same result just using the saw fence?
Yes... the only problem is that you have to change the fence at every cut. Or like Jim says. And to do it good you always use to push the wood between fence and blade. Not on the other side of the saw. That is a safetything. With the jig you push on the good side.Well, I must be missing something here. Can't you get the same result just using the saw fence?
