HMS Victory Mantua 1:78 (first build) by Grant Tyler [COMPLETED BUILD]
Good evening. Needed a break from rigging so decided to work on my dreaded stern.
The rudder chain: deviated completely from Mantua and followed Gil Middleton who used Longridge as a reference.
The rudder chain is used as an emergency system and to secure the rudder when unshipped. I made the hooks and rings from 0.6mm wire.
I lashed a hook to the messenger rope which will be secured to the underside of the aft channel.
I painted the Mantua name plate and stuck it on with prestick so long.
Cheers Grant
Cheers Grant
I was expecting "Grant's Victory".
Cheers Grant
Grant, possibly a rather silly question, but I can't seem to find where the chain is connected to the rudder. That's still work in progress, I presume?
Good morning Johan. You presume incorrectly. I left that out. It should be connected and the this will probably change the hang shape. I will check and have to add some hooks and rings. Thanks for spotting this. Grants oversight. Cheers Grant
Nice lantern Grant, though the real ones are a bit different. And as you can see, on their inner side there is a door, not a glass.
Good morning. Yes They are so different. As I mentioned tho, I'm not there in terms of making these from scratch. I will make the other two and see if they grow on me. Cheers Grant
Good Evening Grant. I'd get rid of the red and replace it with clear glass or clear plastic/Perspex. Wonderful ship you're creating btw. It's a joy following this build.
Cheers.
Grant at play.
The netting above the “steps” on the hull run across the enterance. I did not add covered Hammocks there however this does not make any sense. Surely there would be a space for the sailors to climb on board without climbing the netting?
The Portsmouth Victory has these across as well?
Grants Victory:
Ignore red arrow (pic from prior) post.
I cut away the netting. Pics from other modellers show the railing part carrying through or just nothing? Also doesn’t make sense.
I added a chain with two small hooks. I have not cleaned up yet and wondering what hatch, gate, chain was actually used? If any.
I quite like the chain effect - let’s see.
Cheers Grant
The stern of the Victory looks beautiful Grant! Contrary to what my learned friends say, I think the lantern looks great and if it doesn't look the real one, simply say that you have "simulated" the lantern.
Good morning Heinrich. Yep my “simulated” lanterns are cool. I am happy. They somehow fit Grants Victory. :D Cheers Grant
