Have you tried using a cheater board to get under 2mm? Tack glue the board you are using onto a thicker board. You should be able to get lower than 2mm that way.I have this machine and principally have been quite happy with it. The only thing I don't quite like is the minimum thickness of the strips you want to plane. You cannot get much under 2 mm, which in some cases is too thick for me. And the other drawback is the relatively high price, at least for us retired modellers.
Good idea Sambini! No I haven't tried that but for sure I will the next time I need something thinner.Have you tried using a cheater board to get under 2mm? Tack glue the board you are using onto a thicker board. You should be able to get lower than 2mm that way.
Something that works well is double-sided carpet tape. Just make sure the substrate you choose is flat. I use baltic birch plywood for the carrier and when adjusting my planer, I take VERY light cuts on each pass. Also - plane a board longer than you will need for the finished stock to eliminate any snipe at either end.Have you tried using a cheater board to get under 2mm? Tack glue the board you are using onto a thicker board. You should be able to get lower than 2mm that way.
