Hello,
Here is very small precision drill/mill I’ve made. Some parts i already had and used, so I decided to build something as precise as possible. I have no access to industrial machinery and my goal was to have accuracy no lower then 0.03mm on each axes, keeping in mind that each moving part has 0.01 accuracy.
- Spindle is RATT MOTOR with the speed up to 12000 RPM, Torque 0.5NM, 500W, radial runout 0.01-0.02.
- XYR milling Platform - Manual Linear Table, Tuning Sliding Table, Micrometer Adjustable 0.01mm Accuracy, Parallelism: 0.02mm
- true parallel riser table for drilling, built with two ball bearing linear ( it doesn't tilt or turn, and its very stable )
Milling platform and riser i've used with Proxxon Rotary, drill stand and micro compound table (but had tooo much "play" for my liking)
Two little shims at the top and behind brass bar allows me to adjust Z slider to a true 90 angle
Adding small usb ac adapter for led light.
So far, i'm happy, I may even do miniature drill table with fence, small clamps, and mitre guides
Thank you,
Yuri
Thank you,
Yuri
