- Dec 30, 2021
I have used both Birchwood and Jax products. The ones intended for brass are both chemically the same so the results shouldn't vary. The only difference will be the strength of the chemical. I find JAX very quick to react compared to Birchwoods so it's obviously a stronger solution.That was JAX Copper Blackening solution I had these huge problems with. I now threw this crap away and use Birchwood Casey with success.
The mount of time you metal stays in the solution greatly affects the end result.: stay in too long and a crust forms which will fall off. As soon as the metal starts to turn black it's time to remove it and wash thoroughly in clean water.
Note 1: Chemical blackening only adds a patina coating to the metal, it does not change the colour of the metal.....
I Brush first with a fibreglass brush, soak in Isopropyl Alcohol, remove and dry, then put in the blackening solution. From the blackening solution to water for thorough rinsing then onto paper towel to dry.
Note 2: If you are soldering brass/copper parts not all solders will blacken using the brass blackening solution. This is likely due residual flux (particularly if using electrical flux cored solder) but sometimes because the makeup of the soft solder is not compatible with the blackening solution.
