You set us on a wrong feet, Paul.That was also my thought by the last picture.See this as a compliment, Paul.
Gentlemen,Phoning a friend... Topic: rabbet at the sternpost.
In the LSS instructions it says the rabbet transitions above the bearding line from a shallow V and ends in a U - but TFFM seems to say the rabbet remains a shallow V above the bearding line.
Should the rabbet be more of a U near the top (unlike what is shown in this graphic image)? That would seem to make more sense...but...
Sorry Heinrich. I introduced some abbreviations in my introductory comments but it was careless of me to assume anyone would hang on to my personal shorthand.I understand that LSS is Lauck Street Shipyard, but I have no idea what TFFM means?
Yes Christian. You can purchase a chapter by chapter set of 3D renderings from Greg Herbert. The cost is reasonable in light of what you get (invaluable from my perspective).Wow, this is a beautyful stem. Are there more pictures of the model available? The transition of the rabbet looks good.
Thank you Tobias. That's exactly what I was looking for. This is all new to me so there are many mysteries I need to uncover that the rest of you have sorted out already...Hello Paul I think you are referring to the area marked with the red arrow. In the Ancre monographs this area is also always V-shaped and not semicircular. I think it should be V-shaped because your planks are also at right angles at the end and not rounded to create a clean transition. You also have this at the bow. See pictures.
I pre-milled it with the machine and then reworked it by hand.Thank you Tobias. That's exactly what I was looking for. This is all new to me so there are many mysteries I need to uncover that the rest of you have sorted out already...
Did you mill the groove or use hand tools?
Ditto- exactly what I thought when I saw those pics.Are you modeling now on a computer and make a virtuel model?
It is not a real photo of your wooden model stern post, or?
Don't count on it! I bet they are all equally challenging to a certain extent.I don't believe it will be nearly as complicated as yours
The problem (if it is a problemThe precision required is beginning to concern me. I have been having a hard time committing to the work out of concern that I'm messing something up now that won't be easy to fix later. I find myself thinking: I guess that's right more often than I would prefer...
It seemed best to only partially finish the rabbet at the upper sternpost at this stage. I assume I will be able to refine it later when the transom pieces are fabricated and test-fitted.
The problem (if it is a problem), however, might arise because of limited knowledge and required experience.
I wish I had some build logs of this LSS kit to look at. The ones that exist jump over the part I am working on right now. There are some scratch builds to follow, but the kit deviates in some important ways for the sake of buildability...
This is really helpful Maarten. It all makes perfect sense - now I just need to DO it!Hi Paul,
The shape of the rabbet at a specific point of the keel is depending on the angle of the hull planking reaching the hull at that specific point.
At the bottom of the keel the planking is flush with the keel so the rabbet is cut to countersink the plank into the stern post.
Higher at the stern the hull shape widens and the planks reach the stern at an angle. The end of the plank is sawn square so the rabbet is a V shape. Towards the top of the stem (bow) the planks are reaching the stem at nearly 90 deg in a blunt ship so here the rabbet goes to a type of u shape.
As long as you keep in mind that the rabbet has the shape to absorb the end of a square sawn plank at the angle the plank reaches the keel, stem or stern you are ok. This means the rabbet changes shape all along the hull.
The rabbet was one of the few things which were often cut by the master shipwright himself because of this difficulty.
So if you do it right you can call yourselve a master shipwright.![]()
