I was looking at drawings and models of the Bounty and noticed that it had a capstan and a windlass. Didn't they serve the same function? Why would a ship have both?
I go directly to NMM and also three decksThank you Uwe, that's interesting. Do you mind if I ask what did you use for search parameters? I searched for Bounty and Hms Bounty and came up with 0 results. I figured it had to be wrong but nothing.
yes - usually, when I show a drawing from there I also add the link to this page
indeed, the ratchet capstan is handy as it requires less manpower, but is extremely slow.Seems, that the Bounty had in the beginning only the windlass fore without the capstan
at this drawing the capstan is missing
Bounty (purchased 1787) | Royal Museums Greenwich
www.rmg.co.uk
This drawing is showing than both - with installed capstan and changed hatches
Bounty (1787)
Scale: 1:48. Plan showing the upper deck, lower deck and fore/aft platforms for HM Transport Bounty (1787), as fitted at Deptford Dockyard for transporting breadfruit plants.
The plan was received by the Navy Board on 20 November 1787.
www.rmg.co.uk
After her purchase at 23.05.1787 the Bounty received the capstan later on during the refit to be prepared to transport the plants - so they decided to need tha capstan purely to use for lifting actions (boats, loads, baskets etc.)
British survey vessel 'Bounty' (1787)
British survey vessel 'Bounty' (1787). Dates of service, name changes, previous and next incarnations, dimensions, armament, commanders, officers and crewmen, actions, battles, sourcesthreedecks.org
So I think the windlass for lifting anchor, the capstan for lifting everything else - the capstan was working much faster than a windlass
BTW:
the first drawing without the capstan is dated with 25. June 1787
the second drawing with the capstan is dated with 20. November 1787
