- Nov 4, 2020
Ok! I hope this little tutorial will help you to understand how I make the small hinges:looks beautiful
I would appreciate an explanation accompanied by photos of the process of creating these amazing hinges .
I use a very thin sheet of metal cut into strips of a suitable size:
This metal strip folds back on itself:
to create the hinge I use a very fine drill bit that I insert into the end of the folded metal sheet:
Then with flat nose pliers I gently squeeze to create the shape around the hinge:
Now with a very fine grinding wheel I shape the hinge:
Now simply insert a pin of the appropriate size:
