Now, that is what a call a great RE-DO. And your painting skills paid off, Henk. Hats off!Agree
Just adjusted and first looked again before the photo came
Better for me now
Also the gears have aged
Regards
Henk
Thanks for the compliment PeterSo, that's saying a lot of your talents.
Every aspect of this build poses it's own challenges, the windlass is no exception to the rule.Agree
Better for me now
Regards
Henk
Step by step, Henk and rope by rope; she will become a beauty!Completed today what I was dreading making, and what turned out to be not so bad
As usual, changed a bit As usual, and the cordage made white
Mounted
Backrope and Bobstay's , Peter followed his advice to do this with thicker rope
De Guy attached with slightly thinner rope
( I hope the above the names are correct)
Regards
Henk
The delicate rigging is started! Nicely done, Henk.Completed today what I was dreading making, and what turned out to be not so bad
Mounted
Regards
Henk
Good morning Henk. I have to agree with your earlier post- the Dutch seem to have the ability to produce fine model ships. Catching up a little with your build- excellent work with all the tiny details on this BN. Cheers GrantCompleted today what I was dreading making, and what turned out to be not so bad
Mounted
Regards
Henk
What Henk wrote: works like a charm. Current experience: eyes with an ID of 1,8mm.Already done some previous tests to bend the dead eyes with brass of different thicknesses
The thick and broke off, no success
Got pieces of wire from Peter as a test and that worked a bit better
Ordered wire for Johan and myself with a thickness of 3.5 mm in the colors black and brown
Blemen wire on a roll 100 meters very flexible and the cut and did not break off
This was the Eureka moments for me
Bloemendraad - Ø 0,35 mm, 100 m, gegloeid online kopen | Aduis
Ø 0,35 mm, gelakt, 100 m spoel.www.aduis.nl
Those deadeyes and chainplates; stuff for nightmares, but with a little help from your friends...Put a bolt through it and tighten the nuts, all this on a black cloth.
Everything made matte black on the irons that are turned on a needle in my vices and the production can be started.
This is very easy
I don't blacken dead eyes, I still have trouble painting beautiful wood.
Regards
Henk
