USS Constitution 1:76 Scratch
Hello friends. I am here again with my new project 1:76 scale USS Constitution model. Of course, it will be a build from scratch again. While making the model, I will use the Constitution book as well as the kit plan of Model Shipways. Model Shipways' kit does not include gun deck details, but I will add the gun deck and its details to my model. My current thought is to make full rigging equipment except sails, but I don't know what the time will show because it will be a long-term project. Again, as always, I am open to constructive criticism, comments, suggestions and recommendations.The pictures show what I have done so far and I'll continue to share as I progress. Kind regards.
[FB_IMG_1710788269355.jpgFB_IMG_1710788273468.jpgFB_IMG_1710788278143.jpgFB_IMG_1710788285888.jpgFB_IMG_1710788292378.jpgFB_IMG_1710788309455.jpgFB_IMG_1710788312727.jpgFB_IMG_1710788316306.jpgFB_IMG_1710788319920.jpgFB_IMG_1710788324114.jpgFB_IMG_1710788327802.jpg
Thank you so much for the likes and comments my friends.
I glued the bulkheads and put spacers between them. I always put these spacers as a precaution against warping the keel in later stages.
Do you use basswood or balsa wood for your spacers, or does it matter?
I used plywood for the spacers. But you can use basswood or any other hardwood too. Balsa is not a good idea for the spacer, I use balsa only as a filler in the bow, stern or between the bulkheads if necessary. For example, if distance between two bulkheads are too much you may want to fill it with balsa.
This is truly impressive. I don't think I have the skills to take on a scratch build of this type but I will be interested to see how it progresses.
I agree! I am not to that skill level yet but I do have the Model Shipways USS Constitution in a box ready to start this fall. I will following this build with great interest.
Mustafa my friend
There is no doubt that you create ships of the highest quality, the pace of your creation is most impressive.
I have no doubt that the constitution will also be extremely interesting!!
so I join the other dear members of the fan base and will continue to follow with great curiosity
Good luck and enjoyThumbsup:cool:
I'm Overwhelmingly impressed and not just a fan but a student! Your work is is so instructive and informative. I'm glad and grateful to have found you and your work on this forum. It is of inestimable value.!:oops:ThumbsupOkay
Pete G.
Well, this is off to an excellent beginning. I really like your solution to cutting the plank rebate into the keel, stem and sternpost. Also, the use of locating pins to further solidify this assembly. I don’t wave American flags around too often, but I can’t suppress a certain sense of pride in our old girl, Connie. You will certainly do her justice.
