1:350 Minicraft Titanic Wood Decks
Hi. I'll be putting the Scale Decks wood veneer on my model. What's the best way to sand the original plastic decks down to prepare for gluing? By hand? Has anyone used a Dremel tool for sanding? Any help is appreciated.
Hello, do you have a picture of the deck? I would sand it down with not too fine emery paper, by hand. You have more feeling there.
I agree with Wolle. Do this by hand, making up a small sanding block will help. The decks are thin, using a dremel would be to harsh! I use a x-acto blade also to scrape off the lines. That is all you want to do to get a flat surface, just get the lines out to get a smooth surface for wood deck adhesion.
scraping the surface will work for the most areas - and sanding by hand
with Dremel will be also problemativ, because there could be the possibility, that the plastic could melt partly......
I can imagine, that the Proxxon Pensander could also work on some area
Hallo @Mulberry
