Occasionally wood got burned when sawing due to blade speed too high. Can light dimmer be used with Proxxon FET saw to slow the motor down?
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
he wood mostly get burned by a dull blade or when the saw blade is not p
Most times the wood burns while sawing because of an incorrect blade for the type\sicknesses of the timber. Slowing the motor down will kill the motor unless you are using reduction gear (which is not the case with most table saws). Just have a moment a check the latest Olga videos when she cut 1-inch thick timbers. It is very smooth and clean. She used carbide tipped blade. Also, the thicker\harder wood you have to cut, then use the blade with the fewest teeth. Another suggestion is to move the 'exit' side of the guide just a notch away from the blade. I am using this blade.Occasionally wood got burned when sawing due to blade speed too high. Can light dimmer be used with Proxxon FET saw to slow the motor down?
I will have to find the hard maple in my stash...but, before I do that, I can tell you that I cut the boxwood (Castello) and Pearwood without any burn marks.Hi, Jimsky. Thanks for replying. Could you please take a piece of hard maple and cut it with your blade? Could you let me know if you have burn marks?
I use a similar blade like Jimsky posted and cut hard maple on my Byrnes saw without any burning.Hi, Jimsky. Thanks for replying. Could you please take a piece of hard maple and cut it with your blade? Could you let me know if you have burn marks?
This is the saw I cut with.will this blade fit your table saw?
It is very hard to tell without actually seeing it. It could be more than one reason. Is the blade parallel to the guide? It the blade wobbled?What is wrong with my saw then?
you said you are using the blade I posted, it has less teeth to rip the woodI believe problem is too many teeth. Need to slow blade down.
