Great details on the interior Jan, add s a lot to the kit.
wonderful work, well doneUpdate 15
Last week, my youngest grandson turned 1. My daughter once left for Wales for the beautiful scenery and "stuck" there. So we had to go to Wales to celebrate. However, my son-in-law is an artist at painting fantasy and science-fiction figures. A few weeks ago, I sent him my figurines with a request to paint them. These figurines were very willingly printed by Bert Mogelin at my request and in the desired position and size. See also Mogelin.nl.
Thanks again Bert.
And so I was able to celebrate the birthday and also collect my figurines.
Among other things, the following works of art were assembled (about 6 parts) and painted by him.
All my figurines and a few of his together:
Two seated figurines. If they knew what was behind them they didn't sit so quietly.
On the model, I want to depict daily life on board as well as possible. Daily life takes place on the deck directly above the hold. The deck there is 18 mm high so 1.30 m. Similar to the low deck on the Batavia in Batavialand. (Leliestad)
So not very comfortable, but enough to hang a hammock and climb in it.
Or to have something to eat at a table.
One of the activities on board is visiting the loo. Or the loo or convenience, whatever you call it. The model does not have a galleon so there is nothing there. Therefore, I suppose some kind of convenience was present with a bucket to be emptied regularly. A figure is printed in a seated position with his trousers on his heels and sitting at ease.
One corner on that deck I want to screen off a bit for convenience where then the figure would sit with his trousers on his heels. That will be tricky for a while because the figure is 18mm high. So he is sitting with his head against the deck, but also behind a deck beam. So I need to come up with something for that.
Left: Seen from above through the deck, which isn't there yet, and right seen through the side opening with a deck beam in sight. I might remove that deck beam there as soon as I can.
Furthermore, I have another seated figure that is supposed to represent the captain. He sits in the cabin behind a table with a map and some more furniture.
Here well seen from above and below from the side as seen through the side opening.
Here you can also see the open door to the cabin on the right and the cabin window can be seen on the left.
I can't put these figures in until the trusses are also in place, then I can align the figures on them.
And right in front of the cabin there will be two men operating the tiller with hoists. All visible through the rear opening. The other figures are to brighten up the deck.
To be continued
From research work of Swedish archeologist Niklas Eriksson it seems that on the smaller Fluyt schepen the complete crew was housed in the great cabin and galley in front of it and the small cabin on the upper deck.Maarten, It will certainly be present on the 30th.
I didn't know where the loo was in absence of a galjoen. So I choose a position visible.
Was it a closed cabin in the captains cabin or just an open bank. That is not very plesant.
You’re at a complex and interesting part, Jan. Looking forward to the next steps.Update 18.
After a "ship museum" hiatus, we are back in full swing. And now it's the stern's turn. This is a bit trickier than usual because of my own modifications especially the tiller.
First of all, the ceiling of the cabin has been fitted. Here you can see the top of the ceiling which is colored with vanDijks brown. This roof remains somewhat visible through the hemp hole so it needs to be colored. You can see the tiller running across the roof here.
On the stem beam is a tuning fork-shaped attachment to hold the rising side battens in place. But the tiller has to go through that.
I forgot that under the tiller there also needs to be the sill of the tiller hole frame. Here it is still loose. Here you can also see the two side battens held by the attachment.
The space between these two auxiliary battens and the skin battens applied so far must be filled with three oddly shaped battens that will form the "hips" of the flute.
This way it still looks like something but ..........
Seen from a different angle?
Where is that supposed to go?
I'm going to think about this for a while. But fortunately we had a "Maritime Museum" where *Hans* also attended and so we have an example.
But still .........
To be continued.
Translated with www.DeepL.com/Translator (free version)
Hi Jan. You are now at a very delicate part. A lot of (double?) curved planks. Respect for chosen to do a re-do.Update 19.
After some fiddling, the top 2 of the 3 battens are on. Quite close. There is still a gap left which is too small for the third moulded batten. So I made it to size for this.
Then this is the result:
This will do.
The other hip also done, but I didn't like it so I took that one off again. (no photo of it). But we are moving on again.
To be continued.
An eye-catching part that requires the necessary attention. And you do that nicely, Jan.Update 21.
Yes that hemp hole, that knows what.
I was trying to glue those three little parts together in the desired position. What a mess.
If you glue these two half-rounds vertically to the girder, you get the shape of the hemlock frame, which should look like the yellow window below.
I wanted to try if you could also make this as a whole from a piece of solid. Spruce in this case. Basically the way you would mill a figurine out of a piece of wood.
Picked up a piece of wood and marked off on the sides what it should look like from that side.
Fortunately, I have a Proxxon belt sander and you can sand away a chunk of it in no time.
Then it looks like this:
To fit .............
A little too high. It needs to go back a bit more and then it pushes the bar above it up.
Rejected.
You don't have to start from a piece of square wood, a piece of round wood will do. This should be 15 mm round and then drill a 10 mm hole in the center so that you have a bushing of 15 mm outside and 10 mm inside.
This is not the best photo but here is such a bushing.
After a few similar edits, I can compare them.
And the second one (the bottom one) now just fit with the "tuning fork" against it as well.
One more crack to fill and then I'll live with it.
Now on to building the other loosened side.
To be continued.
