- Feb 23, 2019
Any body know if there are any real difference between the bismarck and tirpitz your help is much appreciated
in short: Bismarck had a single aircraft hangar on each side of the funnel and a double hangar at the base of the mainmast. Tirpitz had two dual hangars on each side of the mainmast base. Four minesweeping paravanes were carried, two on either side of the aft superstructure deck.Any body know if there are any real difference between the bismarck and tirpitz your help is much appreciated
Hallo @Model MonkeyAs others have said in their posts above, one of the more conspicuous differences is the position of the cranes. Bismarck's cranes were located on the main deck, near the edge.
Bismarck:
Tirpitz's cranes were located a deck higher and further inboard and more forward.
Tirpitz:
Below are some photos of models to help show the difference in crane positions, superstructure configuration astride the funnel, and the location of the 105 mm AA guns near the cranes. Positioning the cranes a deck higher and further inboard permitted space to move the twin-gun 105 mm AA guns nearest the cranes on Tirpitz further outboard giving them much better fields of fire than the same AA mounts on Bismarck. The cranes on Tirpitz were positioned more forward too, in order to provide sufficient space for the floatplanes' wings when on the catapult.
Bismarck:
Tirpitz:
As the war progressed, Tirpitz's anti-aircraft armament was significantly increased, namely the 20 mm weapons. Ultimately, she had two conspicuous, circular quadruple 20 mm Flak positions installed, one forward of the bridge, and another, larger tub on top of turret Bruno (turret #2).
Another difference between the ships is the position of the domed searchlight stations on the sides of the funnel. On Bismarck, the domed searchlight station position is 1.5 meters higher than Tirpitz. On Tirpitz, the domed searchlight stations are positioned lower, at or very close to the same height as the platform surrounding the rear of the funnel.
Bismarck:
Tirpitz:
Vielen Dank!!
