I guess we are talking about Plank on Bukheads POB ?Instead of positioning frames in the false keel and fairing the shape for planking is their any advantage or disadvantage to clamping the frames together an fairing before final positioning?
My current method is that the frames that require a bevel I mark the shape at the rear with a marker .Unfortunately fairing the bulkheads is just tedious work…sanding and filing and checking by laying down a plank to see how it fits over the faired bulkhead. You get a start with a plank that you lay across the bulkheads…note the angle…then start sanding and filing the bulkhead edge down to that angle. If you are adept using a Dremel sanding drum that will make faster work of beveling the bulkhead edges. Just do not get carried away and take off too much wood. Anyway…no easy solution…just patience and labor!
Hallo @JIMBO1912My current method is that the frames that require a bevel I mark the shape at the rear with a marker .
I then file to the marker of the frame forward without removing any of the ink on the frames then repeat
It gets me close to what I think is the right shape but I,m never sure if its correct
