hope someone can help me i am looking to buy wooden doors and windows for ship models. thank you terry
Good suggestions. Now I am better informed as to resources.Wooden doors and windows will be a sticky problem…perhaps only available from a forum member adept in cdc milling. I have not found an open on-line source for wooden windows and doors. Plastic is more common under model railroad structure websites. Sometimes you can get batches of random windows and doors that you can fit into your models. I have done this often. Then paint the plastic in a good wood tone acrylic such as burnt umber or burnt or raw sienna. Styrene plastic shapes are my favorite ship modeling resource! Of course there is also the etched brass variety that often comes standard in kits but I like to avoid that when possible. So I will be watching to see if a solution for wood window and door accessories pops up with your inquiry! By the way…I am with Peter…an aging analog guy in a digital world!
Really very good work.Не знаю где можно купить, не разу не видел чтобы продавались окна и двери. Но можно самому изготовить из дерева, нечего сложного в этом нет, хоть работа довольно кропотливая. Вот фото дверей и окон как делаю я, может будет полезно. Ручки - гвозди, имитация петлей - куски проволоки 0.8 мм. Собираю на основании из фанеры 1мм. Нужен минимальный набор инструментов. Если окна, и двери сложной формы размачиваю рейки в воде, и сгибаю с помощью термоапликатора.
